Brakes Lights Out - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > Brakes Lights Out
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-19-2013, 05:12 PM   #1
Hillbilly61
Brakes Lights Out
Still trying to resolve why my lower brake lights will not work (everything else does). The center works OK. This is for an '09 Liberty KK. Here's what has been tried so far:
* Bulbs and fuses checked & are OK. Even bought some new ones and swapped them in. No dice.
* The plugs to the rear light assy were checked with a multimeter and power is present. All I can say, is boy that is a weird setup! Of the six pins, the common ground was found and of the others, some go from high to low or low to high voltage or just drop out altogether - depending upon what is being done... like if the vehicle is in park or not, put into reverse, etc.
* The brake pedal switch was swapped out today. No dice. A new thing was noticed by doing this:
If the vehicle is in park, I can now hear a distinct clicking sound in the dash. If taken out of park and put into drive, the click goes away.
Any thoughts as to what to check out next?
Hillbilly61 is offline   Reply With Quote Quick reply to this message
