Brake lights not working - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Brake lights not working
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-07-2006, 07:48 AM   #1
erickpl
My wife was driving home behind me and asked me why I wasn't using my brakes at all. Turns out my regular taillights (for night driving) are working, my turn signals are working, but when I apply my brakes, they don't work.
I recently modified the 3rd taillight with some new wiring and light, so I am thinking THAT did something to make the brake lights not work. I plan on checking it tonight, but is there anything else I should perhaps look at to see where a problem may lie?
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Unread 03-07-2006, 08:09 AM   #2
Scrambler82
Scrambler82's Avatar
1982 CJ8
I assume that you have a Wrangler.
If your turn signals are working the bulb/ground circuit shold be OK.
Try check the brake light switch on teh brake pedal.
Just thinking.
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Unread 03-07-2006, 08:22 AM   #3
erickpl
Yes, I have a Wrangler. Sorry, I should have clarified a bit. Where would I look for the brake light switch on the pedal? Any pics of what to look for? I don't have the Jeep with me today (don't want a ticket for no brake lights).
I plan on putting it in the garage tonight to work on it so I will find out if the regular tail lights black out when I apply the brakes or if the brighter lights just don't come on.
-Paul
