brake lights going out - JeepForum.com
post #1 of 4 Old 08-10-2013, 11:28 AM Thread Starter
kiss74
when headlights are on and brakes are applied, the left brake light goes out. both brake lights work when headlights are off. I can hear the relays under dash clicking louder than normal, and have dismantled the dash but I don't have the fuse or relay schedule for the panel can someone tell me if any of the relays could be the problem
kiss74 is offline
post #2 of 4 Old 08-14-2013, 07:47 PM
gily25
Any new bulbs or have you removed the assemblies for any reason? Have you ever had a tow harness?
iPhone app user; excuse typos...thanx.
gily25 is offline
post #3 of 4 Old 08-14-2013, 07:52 PM
kitkatoffrd
I had/still have the same problem. Mine is more extreme however. I replaced the flasher unit in the steering wheel, but it didn't do anything. My brake lights don't work, except the one over the tire. The blinkers fast flash. I had to take out the back-up lamps, because when they were in, the entire back would flash hazard when I turned on the blinker.
Still no solution!
kitkatoffrd is offline
post #4 of 4 Old 08-14-2013, 08:51 PM
Holder350
1995 XJ Cherokee
You have a bad ground to the rear light harness. Run a new ground.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
