Blower on Defrost only and Cruise on Fritz - JeepForum.com
post #1 of 6 Old 08-15-2011, 03:00 PM Thread Starter
evillama
2003 Ruby. Pulled the fuse panel off to the side to change my battery yesterday.
All of a sudden today no matter what I set my ac/heater to, it's only blowing out the defrost vents.
Also, my cruise control won't set a speed and stay on it.
Could I have damaged anything while changing the battery? Blew a specific fuse?
It's been raining non-stop here in the NYC area and my vehicle's constantly outside so I don't know if it could've been water damaged or over humidified?
Any help appreciated!
ENV
evillama is offline
post #2 of 6 Old 08-15-2011, 03:22 PM
ajmorell
ajmorell's Avatar
Sounds like you have a vacuum line that isn't connected somewhere.
ajmorell is offline
post #3 of 6 Old 08-15-2011, 09:42 PM Thread Starter
evillama
Yep, that was it. One hose popped out of the driver's side of the intake manifold.
I tested the ac/heater blower and it works fine. Will have to drive it out on the road tomorrow and test the cruise control.
ENV
evillama is offline
post #4 of 6 Old 10-07-2011, 01:52 PM
KevKaos
I absolutely freakin love JeepForum. I was driving down the road today and it was a bit warm, so I wanted the vents to blow on my upper body. Trouble was, it was only blowing out the defrost vent no matter what setting I selected. Came home and checked my Chilton manual, which was useless in this case. So off to JeepForum I head. One quick search, and I hit a bunch of threads regarding this same issue. Sure enough, my problem was the same as the the user above. Pushed the vacuum line back on and all is well. Thanks JeepForum!!!!!!!
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #5 of 6 Old 10-07-2011, 04:28 PM
terpsmandan
2009 JK Wrangler
Happened to me more than once.
terpsmandan is offline
post #6 of 6 Old 10-07-2011, 06:50 PM
KevKaos
Mine is pretty loose. I know the vacuum should hold it on while the engine is running, but I may secure it with a zip tie and then replace it with new when I can get one.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
Add a defrost to soft top model jprscrprs2000 Audio, CB & Ham Radios, GPS, & Electrical 4 05-13-2011 08:47 PM
re-using rear wiper and defrost switches???? herxjhistj Audio, CB & Ham Radios, GPS, & Electrical 5 03-23-2009 06:13 PM
Defrost/Rear wiper switches AMLechner Audio, CB & Ham Radios, GPS, & Electrical 4 11-15-2007 11:23 AM
Electronics on the fritz! Killer Cougar Audio, CB & Ham Radios, GPS, & Electrical 4 04-03-2006 07:26 AM
Rear defrost & wiper switches -other uses? IAJack Audio, CB & Ham Radios, GPS, & Electrical 2 12-10-2005 10:44 AM
