best thing to use - JeepForum.com
post #1 of 4 Old 09-24-2007, 06:11 AM Thread Starter
djXternal
best thing to use
Hey guys, I need to find out if this is going to be the best way of doing things.... I'm going to be installing an inverter in my jeep and want to be able to switch on/off the (+) power cable to the inverter, it will be an 8awg wire... since I do not want to run the 8awg wire to my dash then use a huge switch, would it be best to use a relay on the 8awg wire? and if so what kind of relay would be best to use?
'04 TJ Sport
CB, 3" 4WD.com lift, BDS Front Adjustable Trackbar, Stock D30, ECGS Ford 8.8 Rear (Arb air locker and 4.56 gears), Eagle Alloys Series 187 15x10 wheels, 33x12.50r15 Cooper Discoverer STT's, 1" PA BL, 1" JKS BMML, Viking Fastback Top
djXternal is offline
post #2 of 4 Old 09-24-2007, 07:28 AM
SirGCal
SirGCal's Avatar
The only type of relay that would handle that type of a load (that comes to my mind right now) would be a starter relay.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 4 Old 09-24-2007, 09:21 AM
mylt1
mylt1's Avatar
doesnt your inverter have an on/off switch? as long as you drive your jeep on a regular basis you shouldnt have an issue.
mylt1 is offline
post #4 of 4 Old 09-28-2007, 03:15 PM
Southern Bred
I've put several inverters in big trucks and the relay I use is about $80. It's a marine relay. A starter relay is not made for continuous use and won't last long.
Southern Bred is offline
this thing is the..... herbiehind Fabrication Shop 1 12-03-2009 08:13 PM
What is this thing??? Jaden539 General Jeep & Off-Road Equipment 3 12-18-2008 08:17 PM
Is there such a thing as a D44 manual? UKJeepThang Engines & Drivetrain 2 11-14-2008 12:00 PM
any thing i should know? king_kong General Jeep & Off-Road Equipment 8 02-19-2007 03:00 PM
4.10/4.11 (Are they the same thing?) Wolfpack97 General Jeep & Off-Road Equipment 10 05-18-2002 11:12 PM
