Best place to mount an Amp in a YJ?? - JeepForum.com
post #1 of 12 Old 10-24-2001, 08:24 PM Thread Starter
evilpsych
evilpsych's Avatar
Post Best place to mount an Amp in a YJ??
ok.. some places i have picked out: under the driver'se seat, on one wheel well under a sub box, vertically along the front of the rear seat step-up.. basically, i'm looking for a good place to stick it where it will be out of the way and i can use all of my cargo space.. would building a box for it and venting it with fans work? i think it's a little big to fit into a tuffy box.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 12 Old 10-25-2001, 04:09 AM
bonehead99
bonehead99's Avatar
Post
I removed backseat to fit my 4.5cu ft box and made another box with a double hinged lid to sit in front of my subs. This allows ppl to ride in the back and gives me alot more room.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #3 of 12 Old 10-25-2001, 12:05 PM Thread Starter
evilpsych
evilpsych's Avatar
Post
heh.. that's the thing.. i want it to be a stealth install.. or at least a non-theftable one..
A
post #4 of 12 Old 10-25-2001, 03:17 PM
bonehead99
bonehead99's Avatar
Post
The only thing someone could steal are my amps. My box is huge, you hafta have the tailgate open to take it out. I plan on bolting my amps to the floor. When bolting stuff down don't use phillips or flathead screws, use a star screw. I don't think theives carry star bits with them. To make mine more stealth I want to make the subs down firing.
post #5 of 12 Old 10-26-2001, 12:39 AM
Jefff
Post
Has anyone found a decent 4/5 channel amp that fits under one of the front seats? I dont want to have anything in the back, as I use it a lot.
Jefff is offline
post #6 of 12 Old 10-26-2001, 02:13 AM
braveheart98
Lightbulb
Mines under my driver seat.
It would surprise you what they carry. What I used to bolt down my amp was anti-theft screws. Their use a standard flathead screwdriver to put them in. But the heads are designed so that the screwdriver can only turn the screw one way. If you try to turn them the other direction the screwdriver just slips off the head. If I ever have the need to take them out I'll have to drill them & use a easy out. I picked the screws up at the local hardware store. Another cool Idea I seen posted was using various size bolts to fasten their equipment. A thief doesn't want to take the time messing around with trying to find the right wrench for each bolt. It worked out for the person. Well sort of did... Their jeep was broke into and the crook couldn't get his stereo equipment. But instead of just leaving, they smashed it all.
1994 YJ 4.0L Auto with K&N air filter, 6" inch lift, 33" General Grabbers, Smittybuilt Bumpers, KC Offroad lights and a bunch of other things.
braveheart98 is offline
post #7 of 12 Old 10-26-2001, 03:00 AM Thread Starter
evilpsych
evilpsych's Avatar
Post
puddle splasher.. the only 5 channel amp i've seen, (non competition) is the sony xplod XM-1505SX which is what i'm going with.. i'll let you knwo how it sounds and where i installed it with pics..
A
post #8 of 12 Old 10-26-2001, 09:56 AM
OhYeah
Post
Hey,
A crowbar will rip any of those screw out, and most of the thiefs have, or have access to one of those. And the problem is they really don't care if they damage the amp or the Jeep for that matter, ain't their stuff. My recommendation is L brackets, lots and lots of L brackets for your box and mount your amps under you back seat and figure out a way to keep your back seat from folding forward. Also get a nice alarm.
Peace,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #9 of 12 Old 10-26-2001, 12:28 PM
Willis91YJ
Post
Both Alpine, Audibahn and clarion used to make 5-channel amps. Let me know what you're looking at price wise and I'll get back to you
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
post #10 of 12 Old 10-26-2001, 01:25 PM Thread Starter
evilpsych
evilpsych's Avatar
Post
well.. the idea is to make it look like there's not an amp there, while still allowing me full cargo area and the ability to remove or fold forward the back seat... perhaps it would be best to go with a multiple amp system so they'd be smaller and easier to fit into the tuffy boxes..
A
post #11 of 12 Old 11-04-2001, 05:24 PM
my litte red yj
Post
i mounted my amp for my sub under the rear seat away from any deep water when i put my rear cover on and i also did the same as above i put L brackets on my box in the rear and also did the same for my 2 6x9 boxes on the fender wheel's lots of screws and bracket's
my litte red yj is offline
post #12 of 12 Old 11-13-2001, 01:03 AM
eltj
Post
The best trick that I found is to make a wood or preferable fiber glass false floor on the pass side torward the front as thin as possible . Vent the amp rack as much as possible as well. You may not have to vent it, it will depend on the amp and you will have to experement. If done low profile your factory carpet will usualy cover it and look fairly stock.
eltj is offline
Your favorite place to mount CB. TJ311 Audio, CB & Ham Radios, GPS, & Electrical 18 09-05-2009 07:56 PM
Where's the best place to mount a CB Jeepchick953 Audio, CB & Ham Radios, GPS, & Electrical 42 02-26-2007 04:12 PM
best place to mount a cb radio?? Dylans01jeep Audio, CB & Ham Radios, GPS, & Electrical 5 04-22-2006 11:17 AM
Best place to mount amp for Subs?? HootenTJ Audio, CB & Ham Radios, GPS, & Electrical 11 07-20-2005 11:41 AM
Place to mount scanner. MaddieXJ Audio, CB & Ham Radios, GPS, & Electrical 0 12-28-2002 02:17 PM
