Benefit to grounding to battery rather than frame for a light install? - JeepForum.com
post #1 of 6 Old 01-23-2013, 07:29 AM Thread Starter
ex4rings
I am installing Hella 500FFs on my XJ today and after fully converting the 20g wiring harness to 12g I wondering if there was any added benefit to running the relay ground and lights ground to the battery rather then grounding to the frame like I always have? If I would get better light output for some reason grounding to the battery I would do so, however I am not a big fan of having tons of wires off the battery terminals.
Thanks
ex4rings is offline
post #2 of 6 Old 01-23-2013, 07:44 AM
Sccafire
Why not something like a ground distribution block? That would keep your battery free from a lot of wires.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #3 of 6 Old 01-23-2013, 12:10 PM Thread Starter
ex4rings
Never thought of that, actually never knew they existed. Do you lose any power draw by using them? Any downside at all?
ex4rings is offline
post #4 of 6 Old 01-23-2013, 01:20 PM
terryj
2015 WK
A good chassis ground works fine, the battery ground should be going to both the engine and chassis and as long as the connections are clean and tight you shouldn't see much resistance. The only resistance you will see is within the wire itself, this is why it is best to keep your wires as short as possible. Over time wires will corrode and then heat will start to build up in the wires due to more resistance, the shorter the wire, the less resistance and less heat. Just make sure your wires can handle the amperage.
terryj is offline
post #5 of 6 Old 01-23-2013, 04:38 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
One thing to remember is that if you ground to the battery, you're gonna want to fuse that ground lead. Otherwise, if for whatever reason the main battery ground corrodes/loosens/fails, the starter circuit is gonna find ground through whatever you wired up, should the ground side of the lights/etc actually be connected to the case... Not pretty.
For lights, I'd do chassis ground and fuggetaboudit.
...tom
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #6 of 6 Old 01-24-2013, 05:40 AM Thread Starter
ex4rings
Yeah, I think that is the route I'll go and just ground to the chassis. I think I'll grab one of those Blue Sea Power Blocks to at least keep the battery clean since I'm running upgraded headlight harness, fog lights, roof lights and rear lights; don't really want a birds nest.
...tom
Thanks Tom, good info I am defeintely just going to ground to chassis since its lights I am concerned about. Happen to know the positives if I decide to increase the gauge of the leads to the stock power source, alternator, and ground, was thinking of replacing them all with 4g.
ex4rings is offline
