Battery Problems - JeepForum.com
post #1 of 4 Old 07-07-2013, 10:32 PM Thread Starter
ruby red
ruby red's Avatar
Battery Problems
I have a 2007 JK Rubicon. I installed a Warn winch, Low Jack, Karr Track & another security system (The security systems may seem a bit extreme, but my last jeep was stolen, taken down to Mexico and stripped, so Iím not taking any chances with this jeep). When I installed the last security system, my OEM battery would not support the few extras I put on the jeep. I had changed out the battery 3 times in a year; so I installed the Benchmark Designs Stage 3 Dual Battery setup and used Optima Yellow top batteries a little over a year ago. The setup worked great in the beginning, but now both batteries are dead within a weekís time. I was told after I bought the Optima, that these batteries are not that good, so maybe Iím using batteries that canít handle the extra load. I have checked every new electrical device I have installed and everything is grounded, so that is not the problem. I want to install a CB and Ham radio, but I canít until I figure out a solution to this problem. Any help would be greatly appreciated. Thanks.
"I used to be 'with it', but then they changed what 'it' was. Now what I'm with isn't 'it', and what's 'it' seems weird and scary." ~ Abe Simpson ~
ruby red is offline
post #2 of 4 Old 07-08-2013, 02:32 PM
Vin
First off Your security systems should not be draining that much. They are generally passive systems. I would check for an incorrect ground draining your battery.
Secondly your battery only holds so much of a charge. You still need to charge them. I'd think about upgrading your alternator as well.
Lastly Optima batteries aren't bad. Something in your rig is definitely off if you are draining 2 batteries as you say.
Sent from AutoGuide.com Free App
Vin is offline
post #3 of 4 Old 07-08-2013, 09:53 PM Thread Starter
ruby red
ruby red's Avatar
Thanks, Vin. The problems started with the last security install. I will start there.
ruby red is offline
post #4 of 4 Old 07-09-2013, 08:43 PM
JPNinPA
Measure current draw from the battery with engine off key either on or off. If above 100ma there is an issue. Start pulling fuses until your under 50 MA. Take note of what fuse drops the most current out. That is likely your issue.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
