Battery is fine but wont turn over - JeepForum.com
post #1 of 3 Old 04-26-2014, 10:45 AM Thread Starter
suzette
2009 JK Wrangler
Ive got a 05 manual rubicon, when i turn the key all the lights, radio etc turn on but after that..no crank, nothing. Ive been reading that it could be a ignition switch. Anyone ever had this happen?
For the past couple days when the jeep was running it wouldn't turn off with the usual turn. Id have to push the button in for it to turn off.
suzette is offline
post #2 of 3 Old 04-26-2014, 11:15 AM
strvger01
1966 CJ5
if you hear a "click" when you turn the ignition to start it, it could also be the starter. if not, then i'd start with the ignition switch. perhaps it's just a loose wire and an easy fix. otherwise, it may be the starter solenoid which can be a little more expensive. good luck to you.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #3 of 3 Old 04-28-2014, 09:28 AM Thread Starter
suzette
2009 JK Wrangler
yep it was the ignition switch actuator.
suzette is offline
