Battery drain - JeepForum.com
post #1 of 6 Old 09-30-2013, 04:50 PM Thread Starter
jeepleven
2009 KJ Liberty
Battery drain
Have a 2009 Cherokee limited. In the past 3 months I have, on two occasions, only got the clicking sound as I started up. All the dash lights work and I could remote unlock. The battery appears dead as a dodo! The click,click is, I am told, the starter motor. The Jeep starts under jump leads and the battery charges. Any ideas as to the cause of the apparent total drain of the battery? (Nothing electrical has been left on overnight)
jeepleven is offline
post #2 of 6 Old 09-30-2013, 06:54 PM
fritzj2007
battery drain
Start by disconnecting the ground battery cable and inserting either a test light or a volt meter.If the light lights or it reads voltage then it has a draw on the battery.Start pulling fuses until the light goes out or the meter shows no voltage.that function will be the problem.
fritzj2007 is offline
post #3 of 6 Old 09-30-2013, 07:25 PM
JPNinPA
^^that Plus read the battery voltage with engine off, note if during start if your headlights greatly dim. Read battery voltage with engine running and post all voltage readings. Or just remove the battery, full charge it and have it load tested.
You could have the starter load tested as well.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #4 of 6 Old 10-01-2013, 04:52 AM
Holder350
1995 XJ Cherokee
Clean your battery connections. A bad connection to the battery post can have those symptoms.
Sent from my phone where correct grammar is difficult.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 6 Old 10-01-2013, 08:20 AM
JeepNicholson
Also the grounds to the body
JeepNicholson is offline
post #6 of 6 Old 10-01-2013, 09:48 AM Thread Starter
jeepleven
2009 KJ Liberty
Thanks for the helpful comments. I know where to start now.
