Backup lights -wiring SPDT switch - JeepForum.com
post #1 of 6 Old 03-17-2007, 01:05 PM Thread Starter
IAJack
IAJack's Avatar
I need some help wiring in a SPDT (single pole double throw switch). First off I have seen Stu's site and the diagram there. I am still a little slow and need some help.
I want to wire my aux. backup lights so that in on position 1 they will come on automatically when in reverse. In the middle position they wont come on and in position 2 they would be on all the time.
The problem I don't understand about Stu's site is the switch itself? I have a switch with three connectors on it. The diagram on the switch package says:
Access.(1) Batt. Access(2)
This would be through a relay of course.
So if I understand Su's writeup - the center terminal of the switch is actually ground and not power?
Any and all help appreciated.
NRA-Certified Pistol Instructor
IAJack is offline
post #2 of 6 Old 03-17-2007, 01:57 PM
kencaz
I would do it like this:
Relay: (SPST or SPDT)
Pin 30 to Battery (fused for lights)
Pin 87 to Lights (+)
Pin 86 to Ground
Pin 85 to Center (supply), on SPDT switch
Switch: (SPDT Center OFF)
Center (supply) to 85 on relay.
Load-1 to backup switch
Load-2 to 12v Constant (un-switched) supply
In center position AUX lights will not go on.
In position one AUX lights will go on with backup lights
In position two AUX lights will be on all the time reguardless of backup lights or ignition on.
KC
note: This will not effect the factory backup lights.
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #3 of 6 Old 03-17-2007, 04:48 PM
RLD831
RLD831's Avatar
I used two relays.
Basically it is designed so that when I shift into reverse, it cuts off the switch's ability to power the lights. This way if I leave the switch on and throw it into reverse, I don't blow anything up.
EDIT: Not sure why the picture is so small, if you need it blown up let me know, I'll email it.
RLD831 is offline
post #4 of 6 Old 03-17-2007, 05:11 PM
kencaz
I don't see why that would blow anything up unless you were getting power from another 12V source and not the same battery.
If your lights were on and you ran a jumper between the positive on the battery terminal to the lights would it blow up? No...
KC
kencaz is offline
post #5 of 6 Old 03-17-2007, 06:44 PM Thread Starter
IAJack
IAJack's Avatar
thanks ken, I just needed a confirmation on the way you posted it.
This is looking like tomorrows project. Ever since getting tinted windows and LiteDOTS I cannot see anywhere backing up!
IAJack is offline
post #6 of 6 Old 03-18-2007, 04:36 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I used two relays.
Why not bypass Relay one when powering from relay two, it makes extra connections you don't need.
IMHO, it should work.
Scrambler82
Do it right the first time !
Scrambler82 is offline
Wiring help needed - KC Backup Lights mdlott Audio, CB & Ham Radios, GPS, & Electrical 14 07-18-2007 03:09 PM
wiring backup lights Negative6 Audio, CB & Ham Radios, GPS, & Electrical 2 01-15-2007 09:49 AM
Backup lights switch? bruker Audio, CB & Ham Radios, GPS, & Electrical 2 11-17-2006 11:36 PM
Prob wiring backup lights please help jeepboy21 Audio, CB & Ham Radios, GPS, & Electrical 11 11-02-2006 04:58 PM
SPDT switch? Itchy Audio, CB & Ham Radios, GPS, & Electrical 15 10-02-2006 11:01 PM
