Quantcast Backup Camera - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Backup Camera
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 06-04-2007, 10:17 PM   #1
wenkebach
Backup Camera
Well - I had too much time on my hands this weekend, so I installed a backup camera. We have kids in the driveway frequently, and I thought this might help make sure I don't run over anyone. And, I think its gonna be pretty cool on the trail.
Its a simple camera that mounts to the license plate, and connects wirelessly to a screen in the cab. Simple to install. Bought it at Walmart for $98. Link HERE.
The screen powers up whenever the key is turned on. the camera is fired up whenever the reverse light feed becomes hot. When you shift into reverse, the camera is powered on and sends a signal to the screen inside the cab. There's about a 110 degree pan in the back.
Here are some pics:
First, the camera
[IMG][/IMG]
Another view:
The screen inside:
As you can see, the image is very good - you can see a green cup on the ground behind the jeep, my open garage door, and the driveway beyond.
Also, I have auxiliary reverse lights in the back on a separate switch - so anytime I flip the switch to light up the reverse lights, the camera and screen fire up. This might come in handy at night on the trail.
2005 Wrangler Sport - 4.0L 6 speed
Rusty's 3" Lift, 33x12.5 Trxus MT's, JKS 1.25" BL, JKS BMML, Jeeperman Skidz
Jeeperman Bumper/Pre-runner Bar, Warn Winch, Front Aussie Locker
wenkebach is offline   Reply With Quote
Old 06-04-2007, 10:25 PM   #2
Rocky529
Jeep
Rocky529's Avatar
Good job... I have one too wired into my in-dash player.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 06-04-2007, 10:32 PM   #3
wenkebach
Thanks...what kind of in-dash player do you have?
Old 06-04-2007, 10:38 PM   #4
Rocky529
Jeep
Rocky529's Avatar
Pioneer AVH-5700
I put the camera in my receiver hitch for now, tucks in there nicely. It is wired to automatically display when I put the Jeep in reverse.
Old 06-04-2007, 10:40 PM   #5
wenkebach
Pioneer AVH-5700
Shucks...now I'm gonna have to go look into that.
Old 06-06-2007, 11:22 AM   #6
wenkebach
Someone in our local 4x4 group had an idea of mounting one of these cameras on top of the front differential as a "ROCK CAM"
I can even envision a front facing and a rear facing one, on two separate circuits controlled by two separate switches...... ????
Old 06-06-2007, 10:00 PM   #7
Rocky529
Jeep
Rocky529's Avatar
Absolutely can be done.. if you get a headunit similar to mine I can walk you through on how to wire it.
Old 06-07-2007, 05:58 PM   #8
mike_dippert
hodophobic
mike_dippert's Avatar
http://www.macs4x4products.com/pcustom.html
just a thought
Bestop LJ Halftop for sale. Warm up the cabin faster in the winter!
Jeepiki, the Wiki just for Jeeps
You can't argue with ignorance.
Originally Posted by HurricaneRZA View Post
JF taught me that the 2.5L, Ax-5 and D35 together are so powerful that angels weep when I shift into 4LO.
The only thing a bicycle inner tube is good for, is tying a knot in the end of when you run out of condoms.
mike_dippert is offline   Reply With Quote
Old 08-02-2007, 10:59 AM   #9
PhantomTJ
Pioneer AVH-5700
Which wire did you tap into to get your head unit to automatically go to the camera when in reverse? I just got the JVC AVX33 and installed a camera as well. The camera works just fine when I switch to the right input but it wont switch on when I go into reverse. I tapped into the purple and black wire that is running along the driver's side of my Jeep. I have been told that that is the correct wire but its not working. Any suggestions?
Sorry for digging up an old thread so hopefully you guys will read this. Thanks in advance for the help.
PhantomTJ is offline   Reply With Quote
Old 08-02-2007, 02:55 PM   #10
Rocky529
Jeep
Rocky529's Avatar
I spliced the power into my reverse switch on my transmission. That triggers the camera to turn on.. you can also splice into one of your reverse tail lights. Make sure it is connected to the correct cable on the back of your headunit also... you need more than just the video signal cable to be connected to the headunit.. there is an electrical connection that tells the headunit to turn on the reverse camera.
Old 08-02-2007, 03:20 PM   #11
PhantomTJ
I will try that. The head unit has a separate wire to tap directly into the reverse wire. But when I hooked it up to the purple/black wire it doesnt switch to the camera. The camera works fine otherwise. When I go the correct input on the head unit it shows up fine. Could you possibly send me a pic of where you tapped into? Ill PM you my email address.
Old 08-02-2007, 11:26 PM   #12
CETROV
CETROV's Avatar
mounted a back up camera and tire cameras in mine - don't need a spotter anymore
97 TJ
CETROV is offline   Reply With Quote
Old 08-03-2007, 12:14 AM   #13
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Man that's what I want to do. Maybe next year. Where did you get the monitors and cameras? Can you do a write-up, or more pics?
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 10-20-2007, 05:52 PM   #14
jshaab2
man thats crazy .. i would have integraded the screens into the dash thought
jshaab2 is offline   Reply With Quote
Old 10-20-2007, 05:52 PM   #15
jshaab2
Glock Forum
