Aux switch panel... - JeepForum.com
post #1 of 22 Old 05-08-2006, 09:55 PM Thread Starter
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Aux switch panel...
I saw someone that makes a switch panel to go in the spot above the rear-view mirror... but I can't seem to find it now. It had about 5 slots for the Contura style switches.
Anybody have a link to the one I'm thinking of?
TIA!
I'll be Savvy someday!
neZZr is offline
post #2 of 22 Old 05-08-2006, 10:02 PM
TellyDSP
Poland and PPV!!!!
pretty sure it's a homebrew, but how about this?
http://jeepforum.com/forum/showpost....0&postcount=10
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 22 Old 05-08-2006, 10:23 PM Thread Starter
neZZr
neZZr's Avatar
Not the one
I don't think the space behind that stock piece is deep enough for the contura type switches. Somebody sells a replacement with pre-made cutouts.
neZZr is offline
post #4 of 22 Old 05-09-2006, 07:43 AM
rock_rat
Do you happen to mean this one.
http://www.4x4s-pod.com/
2001 TJ, 4.0, 2.5" OME, JKS Discos, MM e9000, AtoZ Rockers, Skidrow Oil/Engine, Serveral custom WV pin stripes
rock_rat is offline
post #5 of 22 Old 05-09-2006, 08:54 AM Thread Starter
neZZr
neZZr's Avatar
That's it! Thanks!
But I thought they were the Carling switches I wonder what kind those are, because I'll need at least a few DPDT switches in there,
neZZr is offline
post #6 of 22 Old 05-09-2006, 09:24 AM
biffstephens
biffstephens's Avatar
How do you buy one? I am missing the link....
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories.....
Biff
biffstephens is offline
post #7 of 22 Old 05-09-2006, 11:15 AM
ncb76
ncb76's Avatar
Here is my $2 solution
Those sPods are nice....looks like they are blank and you add your own switches? I wonder what the depth is?
EDIT: the faq on the page answered my questions
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #8 of 22 Old 05-09-2006, 12:52 PM
rock_rat
Stupid question, how did you attatch that box ncb76. Where the footman loops in the 97's not rivited like the 01's. Did you drill the rivits or make some kind of clip to attatch to the footman loop.
rock_rat is offline
post #9 of 22 Old 05-09-2006, 08:18 PM
crsmith
Originally Posted by neZZr
That's it! Thanks!
The s-Pod comes in various configurations, depending on what you want. You can have it with switches installed or have it empty and put in the switches (and air pressure gauge, if so desired) by yourself.
I have purchased it and am very impressed with its quality. It was designed by a chap named John Angelastro (Info@4x4s-Pod.com), who is incredibly friendly and helpful. This is a new product which, I expect, will soon become quite popular.
Charles
1985 CJ7 - Dark cherry red with a few mods
2005 Rubicon - Impact orange (The Pumpkin) with some additional stuff
crsmith is offline
post #10 of 22 Old 05-09-2006, 10:13 PM
Willys '05
NBC76 - do yoou have a write up of how you attatched the box and wired it... I REALLY like the way it turned out. Might wanna put one in my baby....
2005 Willys Edition TJ - Rubi rockers - Skids - 30/35 - 3.73 - 2" BDS Suspension - 1.25 JKS BL - 6 Speed NSG- 31" Firestone Destination M/T's - 2 KC 8" HID KCs - 2 6" HID KCs - Dog Box - Rockhard front and rear with swing out and rock rack - Mile Marker SEC8
Willys '05 is offline
post #11 of 22 Old 05-10-2006, 09:53 AM
ncb76
ncb76's Avatar
No write-up, but it's not hard to do. It is a small project box from Radio Shack. I removed the footmans loop (it was held in place w/2 torx head screws) and used the loop as a template for the mounting holes inside the box. I then marked where I wanted my switches to be on the face plate and drilled the proper holes. I drilled a small hole on the bottom side of the box to route the wires, and I used a small rubber grommet (also available at Radio Shack, etc.) to clean it up.
One thing to look out for is the mounting depth of the switch that you use. Make sure it will work before you buy them. The ones that I had were a little too long, so I had to bend the prongs to get them to fit.
ncb76 is offline
post #12 of 22 Old 05-11-2006, 07:07 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
you're not thinking about mine are you?
cause mine works with an XJ. but i'm not sure if it could be modified to work with a tj/yj
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #13 of 22 Old 05-11-2006, 07:22 AM Thread Starter
neZZr
neZZr's Avatar
Yours looks great, but the sPod is the one I was thinking of for my TJ.
neZZr is offline
post #14 of 22 Old 05-11-2006, 07:31 AM
stathunter
Very nice..........what are you using to hold your visors in place? Not that that visors are of much value but I like your setup. thanks
Scott
2004 Black X w/ RE LA 37" SSR's, etc etc
In Michigan? Call Jim from
"Do or do not, there is no try" Yoda
stathunter is offline
post #15 of 22 Old 05-11-2006, 07:33 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
i'm using the stock sun visor clips.
'89 mj tinker toy |
FitchVA is offline
My New YJ switch panel that I'm working on 92 Green YJ Audio, CB & Ham Radios, GPS, & Electrical 6 03-01-2012 05:51 PM
Switch Panel Design Scotch740 Fabrication Shop 21 09-24-2009 11:45 AM
how do I get to the switch panel in my tj bandit455 Audio, CB & Ham Radios, GPS, & Electrical 3 11-30-2008 07:44 AM
My switch panel Comanche_ General Jeep & Off-Road Equipment 0 08-29-2008 01:34 AM
TJ switch panel CETROV Fabrication Shop 1 06-15-2004 04:25 PM
