Audio swap from Civic to TJ sport - JeepForum.com
post #1 of 5 Old 10-03-2004, 03:34 AM Thread Starter
thallex
I currently have some audio equipment in my civic that was installed around '97. Sorry i dont have exact model numbers of most of the equipment. There are 2 JLAudio 10w?'s, 2 MTX Thunder 280's, 2 6.5 MBQuartz's and 2 5.25 MBQuartz. I was hoping that someone here could give me an idea if i could integrate some of this equipment to the TJ and what recommendations they might have. Looking for a config that would be easy and not take up a lot of space. I was only looking to put only one of the Subs in the TJ but willing to accept anyone's/all advice. Want to keep as much storage space as possible and keep as stealth as possible without tearing up rear seat (Sorry SirG!!!) Possible mounting locations for AMP's...etc...you get the picture! Sorry this post was so *amn long!!
thallex is offline
post #2 of 5 Old 10-03-2004, 08:04 AM
ncjeepinyj
ncjeepinyj's Avatar
I have 2 Audiobahn 10's in a down fire box behind the rear seat. Works good i think but no more room left back there. On the plus side the box is just big enough that it cant be easily stolen. It cant be lifted strait up, pulled strait out the back. Some one would have to really work to get it out and with an alarm on the jeep i doubt anyone will stick around longenough to get it.
ncjeepinyj is offline
post #3 of 5 Old 10-03-2004, 08:38 PM
James04TJ
James04TJ's Avatar
I know this is not what you want to hear but unless you have a hardtop & full doors I would leave the stuff out of the Jeep. It is more of a matter of how long before it is stolen than if it will be stolen.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #4 of 5 Old 10-06-2004, 05:45 AM Thread Starter
thallex
Any other ideas?
thallex is offline
post #5 of 5 Old 10-06-2004, 07:17 AM
SirGCal
RIP
SirGCal's Avatar
Sorry for what? My design is not the only way to do it.. Just one of many good choices.. Don't be sorry...
The MBQ's will swap right into the factory locations with very little modification. The head unit should also move (if you have one). Your catch will just be where/how to do the low-end. You have an amp I assume. This may or may not work with just one sub. It really depends on the type of JL sub you have. Since you plan to remove them anyhow, look on the back of the magnet. It should have a model type printed there. There are models: (Bold = current lineup)
  • 10IB4
  • 10W0 (4 & 8 OHM Versions)
  • 10W1 (4 & 8 OHM Versions)
  • 10W2
  • 10W3 (2, 4, & 6 OHM DVC Versions)
  • 10W3v2-D* (2, 4, & 6 OHM DVC Versions)
  • 10W4
  • 10W4-D4
  • 10W5-D* (4, & 8 OHM DVC Versions)
  • 10W6 (6-ohm DVC)
  • 10W6v2-D4
  • 10W6AE (6-ohm DVC)
  • 10W7
So as you can see, which one you have can really make a difference on power requirements. The smaller ones use around 50-75W while the bigger ones can take 1kW continously...
Once we figure out exactly which sub you have so we can figure up how it will be wired, then we can see if your amp will still work with just one sub. (Depending on how they were wired, the amp could be over-powering for just one...)
Once you figure out which amp you can use, then you'll have to figure out where to put it. For 10" subs without using an in-seat option, and without doing any tub modifications, you're left with only one simple method. Behind the rear seat. I do recommend building a sealed down-firing box for best effect and minimum space consumption.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
audio help banks741938 Audio, CB & Ham Radios, GPS, & Electrical 53 06-22-2008 01:19 PM
SPX audio Jeepkiddo Audio, CB & Ham Radios, GPS, & Electrical 2 01-03-2008 07:23 PM
JL Audio Sub Box 04WJGuy Audio, CB & Ham Radios, GPS, & Electrical 5 12-30-2007 11:28 AM
Audio Help Please Coolhand1 Audio, CB & Ham Radios, GPS, & Electrical 5 05-08-2007 05:47 AM
Audio - head unit swap ckracing Audio, CB & Ham Radios, GPS, & Electrical 1 11-20-2006 07:00 PM
