-   Audio, CB & Ham Radios, GPS, & Electrical (http://www.jeepforum.com/forum/f20/)
-   -   Audio Suggestions for a soft-top Wrangler (http://www.jeepforum.com/forum/f20/audio-suggestions-soft-top-wrangler-1345537/)
Burlsworth 03-20-2012 04:40 AM
I have a 2000 Wrangler and i recently upgraded the speakers in the soundbar. They definitely sound better than the stock speakers. I still have the stock stereo in the dash and id like to put in a new one so i can add an amp and maybe a 10" Sub in the back. I dont know a whole lot about car audio so i was hoping i could get some suggestions on how to make the sound better. Thanks
peytonimor7 03-20-2012 08:34 AM
Definitely get an amplifier for your upgraded speakers. I'd say get the same kind of speakers you put in your soundbar, and put them up front (in a different size of course). The amp will let your music get real loud without distorting, which is essential for taking the top off in the summer.
turtle05LJ 03-22-2012 12:00 PM
I am also looking into upgrading my audio. just purchased 6.5" and 5.25" Polk DB Marine speakers and am looking at a Fusion IP-600 head unit since it comes WITH a class D 70wx4 RMS rating so an extra amp is not needed for the 4 speakers. It has an RCA preamp channel for a sub as well. Also is a Marine Head Unit and has a watertight design for iPod placement.
http://www.fusionelectronics.com/mar...eries/MS-IP600
NalinMFG 03-22-2012 12:50 PM
Originally Posted by turtle05LJ (Post 13283972)
6.5" and 5.25" Polk DB Marine speakers[/url]
That's your best option. :thumbsup:
gily25 03-22-2012 01:09 PM
Def look at installing some dash speakers in the same brand. Amping the speakers depends on what model speakers you installed. However adding amp and a quality hu is best for topless wranglers, you shouldn't need to turn the volume up to the point of distortion. 10" sub will fill in the lows for your beach cruisin tunes. If you add a sub consider a "trunk style" enclosure that downfires and maybe use a tonneau if you don't have passengers.
While that fusion is an interesting setup it requires a custom install. I considered a similar mechanism less setup back in the day for my YJ and bought a west marine close out Jensen headunit (turned out to be a good hu for the $) since it was single din. The cost probably ends up being around the same as a mainstream hu and amp with less install effort. Alpine with the power pack is an easy comparable (altho iPod doesn't store inside).
turtle05LJ 03-22-2012 05:52 PM
Just got a message back from Fusion as I thought the 70x4 RMS was a little wierd. It is in fact peak power do RMS is like 26-27 watts at 4 0hms and 43 watts at 2 Ohms so I think I will end up passing on that HU.
Sounded like a great idea though :-)
turtle05LJ 03-22-2012 05:54 PM
Oh and I purchased the NALIN 5.25" speaker adapter!! :D
NalinMFG 03-22-2012 09:47 PM
:thumbsup:
rdnck_8 03-24-2012 07:37 AM
I am in the same spot, to amp or not to amp. I got an 09 Unlimited, put a Kenwood hu in and the stock speakers can't handle it, gets very distorted at med volume, can barely hear it with the top off. Unless I remove all bass. So I ordered Kicker DS65.2 componets for the front and DS65 for the sound bar. Now the question is do I want an amp with them? My thought is that the speakers will handled the higher volume fine for me to hear it just fine so I am leaning towards no amp. Don't need it blaring, just want to hear it.
peytonimor7 03-24-2012 09:49 AM
You'll definitely want an amp for a component system.
gily25 03-24-2012 11:04 AM
Amping a comp set is a good idea. Did you already have the dash tweeters in your oem setup? If so you'll probably want to run new wiring to eliminate any factory crossover that might be inline.
Kurtmccormick 03-24-2012 01:44 PM
Hay guys i just put this years newest Kenwood model, i have infinitely speakers installed in the sound bar. Just the deck itself does a great job at powering the speakers. It wicked loud, plus i have the deck that has blue tooth capability so i can talk on the phone without hanging on the cell and shifting at the same time. It also has the out board mic so the people you talk to can actually hear you, unlike previous Bluetooth stereos. The price tag on this stereo was only three hundred, but if you look around on the internet you might be able to get it cheaper.
rdnck_8 03-24-2012 06:09 PM
There are OEM tweeters, which is surprising since it does not have an infinity amp, but I figured to bypass any issues I will rewire direct to the hu. It a good thing I ordered them the other day cause one of the tweeters fried today.
peytonimor7 03-24-2012 10:49 PM
Which model is this? KIV-BT901? I have that and love it.
Kurtmccormick 03-28-2012 05:27 PM
its the K D C - X996, my only problem with this is that when i stream through the blue tooth i can only hear the two front speakers working. I can't figure out why.
The time now is 04:37 PM.
