Anti - Theft Sub Boxes - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Anti - Theft Sub Boxes
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 07-19-2003, 07:03 PM   #1
Cartman
Anyone know of a good way to get the boom without the boom gettin ripped off?
Cartman is offline   Reply With Quote
Unread 07-19-2003, 07:10 PM   #2
Cartman
In a 97 TJ
Unread 07-20-2003, 12:01 AM   #3
only in a jeep cj
1) form fitted box that follows the contours of the seat back and tail gate so it can't be lifted straight out with out the rear seat being folded down and the box "worked out"
2) don't face the subs up so they can see what to steal.
3) use an alarm
4) don't boom in the mall parking lot before you go inside for 2 hours
5)if box is carpeted, use same color as the interior so as not to make it stand out.
6) "L" brackets bolted to the rear seatbelt bolt locations.
7) Be carefull where you park and keep one eye out.
8)Don't show off your system to ALL your friends, and thier friends, and thier friends....
9) make your buddy drive everyone to the movie in his car
10) use common sense
So far 11 years and no theft!
......the garage, motion lights, alarm, dog and Glock help too!
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 07-20-2003, 09:09 AM   #4
Cartman
"and the glock help too" ha.
Unread 07-21-2003, 06:42 PM   #5
MAjeep87
other little things are use flat head and phillips. Also fill in the whole with rubber cement. that why when they try to put the screw driver in to up bolt it they cannot get it in. also keep it out of site. i made a board that fits right behind my back seat i then covered that in a bunch of plastic then i carpeted the board. i now have the security and it is waterproof for the amp.
87 jeep wrangler
95 4.0l engine and 5 speed tranny.
magnaflow high flow cat
flowmaster deltaflow muffler
MAjeep87 is offline   Reply With Quote
Unread 07-24-2003, 05:01 AM   #6
ROBC3189
I have a sub box that fits tight behind the back seat and back gate, and its tight between the wheel wells. I ran the amp under the seat with the wires all hidden under carpet and in the roll bars. I left the factory head unit in and ran a line converter to the soundbar for the rca cables. Also on the back seat lever I bought a long master lock and put it around the arm there so that you would have to cut the master lock or have a key to raise the backseat.(which when i need back there again I will even have a hard time because it is extremely hard to get to). With the carpet on the sub box, and everything hidden. The only way you can really tell I have a system is the sound. I really like to think it's theft proof. Hopefully I won't have to find out.
ROBC3189 is offline   Reply With Quote
Unread 07-24-2003, 08:04 AM   #7
kdavis
If you're really worried about it, this is a nice design, with some time, you could copy it (this guy has a ton of pics), or just wait till he's back from his baby-sebbatical and order one. The cutouts will lock it in place.
http://www.just4effect.com/10SUBBOX.htm
<>< KD ><>
What I Have: 1994 Grand Cherokee Limited
2.25" 4 Wheel Customs Spacer Lift
Cragar Soft 8's, High Tech Retreading OTR Muds, New Front End
What I Do: MT Web Guy
kdavis is offline   Reply With Quote
Unread 07-26-2003, 10:42 PM   #8
DanG
for my jl 12w3's i used bolts from the inside of the box through the floor and used square head screws to hold the speakers to the box.
89 RED YJ
sitting in driveway next to wrecked car
[URL=http://www.cardomain.com/id/djg6678]my jeeps page[/URL]
[SIZE=4] [COLOR=red]NE[/COLOR][COLOR=white]Off[/COLOR][COLOR=blue]Roading[/COLOR] [/SIZE]
H2RT MEMBER
[color=red] RED JEEP MEMBER #49[/color]
POS JEEP MEMBER #3
DanG is offline   Reply With Quote
Unread 07-27-2003, 06:32 PM   #9
Cartman
i happen to be somewhat of a handyman myself so i think im going to put all of your posts together and make some of my own. Has anyone ever done fiberglass boxes themselves???
--Matty--
Unread 07-28-2003, 04:31 PM   #10
MAjeep87
this write up is the most complete to help you fiberglass the first time. read the whole thing it is not hard just time consuming the first couple of times. i would do a few practice boxs first.
http://chris.pfharlock.com/glass/
87 jeep wrangler
Unread 08-02-2003, 08:57 PM   #11
JimDandy
http://www.tuffyproducts.com/consoles/tj/067.html
Just another idea, but limited to single 8" sub.
03 Sport sold!!!
JimDandy is offline   Reply With Quote
Unread 08-03-2003, 12:23 AM   #12
jt_Jeep
I spent the almost the whole day today making false floor for my 12". I got the idea from Tanzjeep site (http://www.cardomain.com/id/tanzjeep). It should secure enough...
I'll try to post pic when I finish with it..still need to hook up the cables.
'95 Wrangler 2.5L Rio Grande, Tera Low T-case 4:1, 5" Procomp Coil Spring Conversion, ARB front & rear locker, TJ passenger inner axle shaft, Advance Adapters HD SYE & HD drive shaft, 4.0 TB, 8mm spark plugs wire, platium +4 sparks plug, MSD Coil, Sanden OBA / 2.5 Gallon tank, 33" Goodyear MT/R, K&N filter, Flowmaster, 16" Electric fan.
- http://photos.yahoo.com/jete_cobra
jt_Jeep is offline   Reply With Quote
Unread 08-05-2003, 11:05 AM   #13
sp@n|<y
the only thing i would worry bout in puttin a system in a jeep is it gettin wet. is there anyway that i could keep my subs safe while muddig or wheeling?
1990 yj on BFG 32 AT
sp@n|<y is offline   Reply With Quote
Unread 02-13-2010, 07:24 AM   #14
collegejeeper21
Keepin the Subs and Amp Dry
I have two 12" Memphis Subs and a 500 Watt Kenwood Amp, my sub box sits against the tailgate (subs facing the tailgate) It's a ported box, (my friend is a Car Audio FREAK) To keep them dry, I lifted the sub box 2 inches from the tub with rails going down the sides, but otherwise, when I made the box, I sealed it with bedliner, so it's water proof (unless it gets submerged, obviously). But that should give you an idea on keeping everything dry. My Amp is mounted at a 45 degree angle on the top of my box facing towards the front of the jeep with a sealed piece of MDF over the top of it to shun water around it.
collegejeeper21 is offline   Reply With Quote
Unread 02-13-2010, 07:27 AM   #15
jeepster425
^ why did you bring up a 6.5 year old thread?
D30 front/ D44 rear
__=====,o00o,
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|
lllllll|
{o}_} {o}_}--o-}_}
jeepster425 is offline   Reply With Quote
