antenna weak - JeepForum.com
post #1 of 22 Old 04-28-2009, 11:24 PM Thread Starter
lilbluetj
antenna weak
the factory antenna on my wrangler isnt picking up an stations on scan and when i do a manual search its super noisy on the one station i get how do i get my radio to pick up more stations because its sad right now. THanks
LiLBlueTJ
</3 miss that TJ 'Jenny'
lilbluetj is offline
post #2 of 22 Old 04-29-2009, 06:43 AM
SirGCal
RIP
SirGCal's Avatar
plug in the antenna. One plug at the back of the radio, and another one behind the glovebox that can come lose.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 22 Old 04-30-2009, 07:49 AM
LimitedHemi
2nd SirGCal- theres an extension that runs from the antenna to the back of the glove box, and then from there to the radio, they can easily come unplugged at one of the those points when removing the radio.
LimitedHemi is offline
post #4 of 22 Old 04-30-2009, 09:16 AM Thread Starter
lilbluetj
ok ill look i had the radio installed at best buy so i was hopeing they would do it right thanks
LiLBlueTJ
post #5 of 22 Old 04-30-2009, 10:04 AM
Knocky
Ask Chrysler why they installed the antenna line in pieces then.
Knocky is offline
post #6 of 22 Old 05-01-2009, 10:15 AM Thread Starter
lilbluetj
lol ok ill get on that
LiLBlueTJ
post #7 of 22 Old 05-04-2009, 10:15 AM Thread Starter
lilbluetj
so i checked in the glove box and the needle type extension i think you guys are talking about is pluged in. So what do i do know also my speakers i bought dont fit the size of the hole does anyone have the brace or braket so you can put 4x6's in the dash?
LiLBlueTJ
post #8 of 22 Old 05-04-2009, 10:28 AM
SirGCal
RIP
SirGCal's Avatar
You have to have a bracket to install them. That's why I always recommend going to 5.25" speakers anyhow since you have to get the bracket. You get a lot better sound out of the larger round driver than the tiny oval...
SirGCal is offline
post #9 of 22 Old 05-04-2009, 10:33 PM Thread Starter
lilbluetj
ok these are arnt ovals i have 4x6 infinity component style cones on the same thing i just need the bracket.
LiLBlueTJ
post #10 of 22 Old 05-05-2009, 08:06 AM
SirGCal
RIP
SirGCal's Avatar
Same result. Tiny no mids 4" speaker. Same result though. Need brackets either way.
SirGCal is offline
post #11 of 22 Old 05-05-2009, 09:40 AM Thread Starter
lilbluetj
really so the round 5.25 just fit in the dash spot with no mod ill look into this
LiLBlueTJ
post #12 of 22 Old 05-05-2009, 09:43 AM
SirGCal
RIP
SirGCal's Avatar
on some model TJs, you have to use tin snips or something to remove a useless metal brace in the dash for clearence (pictures 2 & 3: http://www.sirgcal.com/2ktj/pics.html?section=dash), in later TJs, the brace is not there. Adapters can be bought or made, there are templates everywhere.
SirGCal is offline
post #13 of 22 Old 05-05-2009, 10:08 AM Thread Starter
lilbluetj
could you make me pair of brackets like that? so the only mod to the jeep is removing the bar.
LiLBlueTJ
post #14 of 22 Old 05-05-2009, 10:18 AM
SirGCal
RIP
SirGCal's Avatar
http://www.flickr.com/photos/photohy...91683/sizes/o/
Or you can buy some. There are some good plastic ones out there and 33 eng makes a set for the dash. I'm sure someone will post links somewhere or do a search. They are posted up here about once a week.
SirGCal is offline
post #15 of 22 Old 05-05-2009, 10:26 AM Thread Starter
lilbluetj
ok sweet thanks i will get around to getting those in ill get back to you guys. also the ball on top of my antena is gone could that lead to a loss in singnal strength
LiLBlueTJ
my cb antenna topper fell off. does this matter? will it affect my antenna PJNovinskee27 Audio, CB & Ham Radios, GPS, & Electrical 3 11-03-2008 03:59 PM
can I use a police scanner antenna 4 ft. from a cb antenna? BigOrangeXJ Audio, CB & Ham Radios, GPS, & Electrical 11 05-08-2007 09:01 AM
using firestik antenna as radio antenna? got_4_lo Audio, CB & Ham Radios, GPS, & Electrical 9 01-11-2006 07:39 PM
Run CB radio antenna through old cell phone antenna wire? FASTnSPEEDY Audio, CB & Ham Radios, GPS, & Electrical 8 09-26-2005 01:12 PM
Steel Spring for CB Antenna and Antenna cable question Bob J Audio, CB & Ham Radios, GPS, & Electrical 23 01-16-2003 07:02 PM
