Antenna Plug or Short Antenna? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Antenna Plug or Short Antenna?
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 04-09-2007, 02:30 PM   #1
rastadog
rastadog's Avatar
Hello,
I installed the SkidRow mirror relocators and removed my antenna because the passenger mirror now touches the antenna. I have XM anyway so I don't really care about regular radio. I would like to plug the antenna hole with a screw or maybe take my dremel and cut the antenna down? What do y'all think of that? What's the matching thread size for the antenna and/or should I just cut my antenna down to fit...or does it even matter if there's nothing in my naked antenna hole?
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline   Reply With Quote
Unread 04-09-2007, 05:04 PM   #2
Scrambler82
Scrambler82's Avatar
1982 CJ8
You are talking about your standard broadcast antenna, why ruin it ?
Take the antenna off of the vehicle and put it away just in case.
The open hole can be blocked in a lot of ways but thing waterproof.
This will bump you TTT, maybe someone that konw what they are talking about will help you.
Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Unread 04-09-2007, 06:12 PM   #3
Chloetar
Ummmm. NnF I usually follow you, but what?
'00 GC Laredo 4.7 / FM Delta Flow 40 Series / K&N Drop in /Rancho 5000's and Steering Stabilizer / Uniden 68LTW CB w/4' FS II
Chloetar is offline   Reply With Quote
Unread 04-11-2007, 09:32 AM   #4
rastadog
rastadog's Avatar
Yup, standard broadcast antenna. I think I'll look for an old antenna from a salvage yard and cut it down so I've got a perfect plug...unless there's a perfect thread match that you know of?
...and thanks!
jim
Unread 04-11-2007, 10:53 AM   #5
Baotchi
2010 JK Wrangler
I ran without it for a long time, just unscrew it, what's the problem with it?
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline   Reply With Quote
Unread 04-12-2007, 08:32 AM   #6
rastadog
rastadog's Avatar
No problem with the antenna, I installed Skid Row mirror relocators and the antenna touches the mirror now - I don't like that. I just want something to plug the antenna hole or just make a stubby antenna from a spare.
Unread 04-12-2007, 09:30 AM   #7
Scrambler82
1982 CJ8
Just to clarify I was thinking do not cut the original antenna save it and block off the hole in another manner, just as rastadog picked up on. The idea of blocking the hole I said to think waterproof, no matter how rastadog decides to block the hole he should make sure it is waterproof.
I'll try better next time...
Scrambler82
Unread 04-12-2007, 09:52 PM   #8
Chloetar
I'm with you now.
