another stupid cb question - JeepForum.com
post #1 of 6 Old 09-11-2004, 06:44 PM Thread Starter
Hilljack27
Hilljack27's Avatar
Wink another stupid cb question
i debating to mount my antenna either using the existing holes used to mount the stock tire carrier and 3rd brake light with a 3ft antenna or using a lower location and using a 4ft antenna.. if the tips of the 3ft and the 4ft antennas would be about the same level, will the 3ft antenna work just as well as the 4ft or would the extra foot give me a better signal?
2000 TJ Sport
3" BDS Suspension Lift
1.25" JKS Body Lift
33" x 12.5" Mud Terrains
Aggressive style but a practical everyday driver.
Hilljack27 is offline
post #2 of 6 Old 09-11-2004, 06:51 PM
Frozen_TJ
Frozen_TJ's Avatar
2016 MK Patriot
In the end you want to get the top antenna about a foot above the Jeep. If you don't then you will get as good of a signal.
What I do is in the city I run a 4' antenna. But when I go on the trail I run a 3' so I do not hit the trees as much. My mount is on the tire carrier. And on the trail I am not very far from the people I am running with.
Official JeepForum Secretary Of Foreign Relations
Alaska Jeep Member #1
Red Jeep Member #233
Frozen_TJ is offline
post #3 of 6 Old 09-11-2004, 06:53 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I run a 2' antenna everywhere I go and it works great. I'm not sure why you're saying it must be at least a foot above the top since RF travels through fiberglass and fabric like it's not even there.
Jerry Bransford is offline
post #4 of 6 Old 09-11-2004, 07:19 PM
Frozen_TJ
Frozen_TJ's Avatar
2016 MK Patriot
When I run my 3' I can hear in the stereo. But when I run my 4' that sits about a foot above I do not get that. I have found for range the taller the better. But that also can change do to location. And whats around you.
post #5 of 6 Old 09-11-2004, 08:42 PM
James04TJ
James04TJ's Avatar
The tire carrier works very well. If you choose to mount it to the bumper you will have to spend a good bit of time working out an acceptable SWR.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #6 of 6 Old 09-17-2004, 09:50 AM
Milt
Milt's Avatar
As with many other things: BIGGER IS BETTER
Milt
Milt is offline
Stupid Question Mon Don Tires & Wheels 1 10-01-2007 08:12 PM
stupid question Maximummud Tires & Wheels 4 03-13-2006 06:53 PM
this may be a stupid question losfreddy General Jeep & Off-Road Equipment 9 02-27-2006 01:43 AM
Stupid Question SurferJeep88 Tires & Wheels 7 12-13-2005 04:21 PM
another stupid question. savage118 Tires & Wheels 2 10-22-2003 01:33 PM
