Amps Under Rear Seat - JeepForum.com
post #1 of 8 Old 06-19-2013, 09:22 AM Thread Starter
JAngeli
Hi, I'm thinking of places to put 2 Alpine amps in my 99. I know a number of you have installed amps under the rear seat. How do the amps hold up under there? Do they get overheated?
Thanks
Joe
JAngeli is offline
post #2 of 8 Old 06-19-2013, 09:28 AM
Ro66y
I have a 600 watt amp under my rear seat and it has never overheated. It's pushing two 12s. I also live in Mississippi and in the summer it gets to over 100 degrees and still no problem.
Ro66y is offline
post #3 of 8 Old 06-19-2013, 10:20 AM
Indy
Indy's Avatar
As long as there is an air gap it should be fine.
I'm the only gay eskimo.
Indy is offline
post #4 of 8 Old 06-19-2013, 01:59 PM
Necko2529
I put my Rockford Fosgate 500 under the rear seat and have no problems with heat down here in Phoenix AZ where temps exceed 115F daily.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #5 of 8 Old 06-19-2013, 04:23 PM
ACrippledFerret
2014 JK Wrangler
Thanks
Joe
I have two amplifiers, one for my highs and one for my subs. Both are under the back seat. The highs amplifier is cooled by a fan and stays fine. The subwoofer amplifier is not and will overheat on hour+ car trips at full tilt.
ACrippledFerret is offline
post #6 of 8 Old 06-20-2013, 01:47 PM
gily25
It really depends on the amp and the duration of use of the amp. Alpine makes a solid amp, they should be fine. You can raise the seat using body lift pucks if you want more airspace.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #7 of 8 Old 06-24-2013, 11:27 AM
chopstix333
I have a 4-channel Eclipse amp for my speakers and a Alpine Mono for my subs. The 4-channel is fine under the back seat since it doesn't work too hard, but when I had the Alpine MRP-M1000 amp under it, it would overheat after a hour or so. Like others said, make sure you have a gap between the top of the amp and bottom of of the seat. The Alpine amp was taller than the 4 channel, so it was touching the bottom of the seat the whole time which wasn't good. I also had a 5-channel Planet Audio amp under my back seats before and it would overheat after 30 min. I'm in Houston.
'98 Jeep Wrangler 2.5L | 4" Pro Comp Lift | 33x12.5x15 Dunlop Mud Rovers | Two 10" Polk Audio Subwoofers | 2 Amps (800w Eclipse and Alpine MRP-1000 Mono) | Kenwood Head Unit | Ham Radio w/ Comet SBB-7 Antenna (Call Sign: KK4BUE) |CB Radio | Hella Vision Plus Conversion with 50w 6k HID bulbs | Lotta Lights |
chopstix333 is offline
post #8 of 8 Old 06-26-2013, 11:12 PM
higgins192
I have a 1000W Pyrimid Amp under my back seat held down by screws in the tub. It was connected to a 10" MTX audio sub which has been replaced by a bazooka tube so my 10" dub and 1000W amp is for sale
higgins192 is offline
