Quantcast Amp wiring question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Amp wiring question
Old 11-20-2009, 10:43 AM   #1
grand95zj
Amp wiring question
ok my question is this. i have a 95 zj and i was wondering if there was a way to take my factory amp thats under the rear seat and somehow link another identical amp to it somehow to double the power somehow?
i had my amp pushing some weak 12s but it kinda pounded actually believe it or not. lot of my friends were suprised it was a factory amp, but any questions would be awesome. thanks
grand95zj is offline   Reply With Quote
Old 11-20-2009, 11:14 AM   #2
SirGCal
SirGCal's Avatar
No, can't do that... You can't pair two different amps on the same output source (speaker). You can use the same input to signal two amps, but...
The only way to put two amps to one sub for example is one per coil, but they have to be identical. Other than that you can't do what I think you're thinking.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Glock Forum
