AMP under hood? - JeepForum.com
post #1 of 10 Old 10-23-2002, 09:51 AM Thread Starter
Torn66
AMP under hood?
I am putting in a K&N come filer and therefore wont need my stock air filter box. I have a small amp i want to use to power my sub...anf thought for theft reasons no one will look under the hood for it. If i was to mount it in the stock fiter box w/ no cap- would i get enough cool air?
has anyone ever done this...Id really like to avoid putting it under the rear seat if i could.
I have the sub on trailer plugs so i can pull it out in seconds...that way w/ the sub out there would be no equipment in the cab...any ideas suggestions????
06 Rubicon
2in BB__1in BL__32 BFG Muds__SIRGCAL in seat box
Torn66 is offline
post #2 of 10 Old 10-23-2002, 10:04 AM
Jeepfreak81
Jeepfreak81's Avatar
Id be real cautious about doing this, water can get in that air box easily, especially cuz it sits low, if you wheel in water or even drive in rain water can get in through the front of the box, if you could seal it somehow and still get airflow it would be a good idea. But water is the biggest hinderance.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #3 of 10 Old 10-23-2002, 09:28 PM
White-Knight
Yeah...agreed water is the big problem. That and the heat from the engine - your amp isn't designed to be run around other equipment that is that hot. Plus, things tend to get dusty/oily under the hood - not a good idea if you're looking for a reliable amplifier. If it's got a fan, then it's definitely a bad idea. If it doesn't, then you're mainly looking at the connectors and potentiometers corroding. Either way, not the best of conditions. If it's small enough - perhaps you could mount it somewhere inside the vehicle say back under the dash or something? That will all depend upon your amp size of course. Otherwise look around under the plastic paneling for space.
'96 Jeep Cherokee Sport (Moss Green, 4.0L HO, automatic transmission and Command-Trac transfer case, Custom 4x4 Tow Hook brackets and hooks, Class III receiver, Blazer 55w Fog Lights). Green Jeep Club Member #17
White-Knight is offline
post #4 of 10 Old 10-23-2002, 09:57 PM
Diggin'Taters
Diggin'Taters's Avatar
I have to agree with the general consensus here. Very not good idea. Have you considered a center console mount? That is a possibility depending on the physical size of the amp.
USAF Jeep Club Member #14
White Jeep Club Founder Member #1
REDNECK JEEP CLUB Member #1.1 and President!
Medical Cannabis Jeep club (I know I'm not the only member)
Diggin'Taters is offline
post #5 of 10 Old 10-24-2002, 06:56 AM Thread Starter
Torn66
Not really- I dont have a center console.
I ws most concerned with the heat in the engine compartment. I can prety much seal the enlosere- but iwas worried about the lack of air and heat- and if those would have a big impact.
Its a precision power amp- not really air cooled and never really ran too hot.
06 Rubicon
Torn66 is offline
post #6 of 10 Old 10-24-2002, 10:20 AM
FloridaXJ
Even if it never ran hot before, it will if your runnin the speakers wires from the hood to the back. Mount it under the dash, BUT DO NOT mount it upsidown..
96 XJ 4.5 Rustys lift, 33x1250 cooper muds, tons of extras, empty wallet
FloridaXJ is offline
post #7 of 10 Old 10-24-2002, 05:12 PM
jmeyer722
mount ti under the driver's seat. thats what i did. its gets enough air to stay cool and is protected by the seat.
1995 Jeep Wrangle Rio Grande, 4" Superlift, 32x11.5x15 BFG Mud Terrain on American Racing AR-136 Wheels, Pioneer CD Player, 12 Disc Pioneer Cd Changer, 2 8" Rockford Fosgate Subs mounted under back seat, Punch 100 amp under drivers seat, Factory hard top w/full doors, Factory soft top w/half doors, Bikini top, Duster cover, K&N filter,...More to come
jmeyer722 is offline
post #8 of 10 Old 10-26-2002, 01:36 PM
monkeywrench
amp
i put an alpine 3522 about 10 inch long by 6 wide 1 thick i mounted mine under the drivers side of the dash with plumbers tape near the stearing shaft food fot thought
jamie 92 yj 4 1/2 RE extream duty 2 body 35-12.50-15 4.56 arb frt rr yorkair warn 9000 zenon flares tomken tire rack 4.0 borla header magnaflow exhaust flexes awsome CURRIE 9INCH HIGH PINION IN THE REAR WITH DISC BRAKES ITS SHAVED TO just added TERA LOW 4 TO 1 TRANSFER CASE KIT
monkeywrench is offline
post #9 of 10 Old 10-28-2002, 01:35 PM
Jim Shanks
Jim Shanks's Avatar
I mounted mine right underneath the rear seat. Put carriage bolts thru the tub with lock nuts underneath. If they want the amp, they'll have to spend some time underneath it.
HTH,
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #10 of 10 Old 11-01-2002, 11:30 PM
brad bowen
Thumbs up
i would have to say they are all right about the haet thing. i got a jensen 400 watt amp i i thought about putting it in the glove box with a couple of fans one to push the air in and one to pull it trough the other side but my amp is too big and j.c. whinety does not sell a larger glove box. but you can make one out of sheet mental and it does not take all that long . i had to mount mine on the wheel well and it is screwed in with some long screws that are made for a camper with a square head insert so if they do not hada that type of driver they will not get it
brad bowen is offline
Dents on Hood drerict General Jeep & Off-Road Equipment 1 07-21-2008 02:51 PM
What do you think it would run just to have the hood done? MusicMaverick General Jeep & Off-Road Equipment 6 12-29-2007 12:41 PM
Need an XJ hood Air Dog General Jeep & Off-Road Equipment 5 12-10-2007 02:44 PM
Hood Pin wenkebach Audio, CB & Ham Radios, GPS, & Electrical 4 08-04-2007 09:10 PM
fan in hood lrsmithwhaley Engines & Drivetrain 3 07-24-2006 09:06 PM
