(amp output) RMS power vs. dynamic power - JeepForum.com
post #1 of 4 Old 07-18-2005, 04:25 PM Thread Starter
orangez
if an amp says
RMS power @ 12.5
140 x 2 into a 4 ohm load
and....
Dynamic power @ 14.4
200 x 2 into a 4 ohm load
how do you know what you are getting?
ROLL TIDE!!! LSU SUCKS!!!
Originally Posted by boonethelunkerl View Post
now all i need to do is learn how to work on my own stuff, that is prolly 5-10 years down the road though
orangez is offline
post #2 of 4 Old 07-18-2005, 04:52 PM
kappaknight
You are getting this when your car is turned off and you are running the system off of the battery's 12.5V
RMS power @ 12.5
and.... you are getting this when your car is turned on with the alternator charging your batteries at 14.4V
HTH. This is a sub amp I assume?
kappaknight is offline
post #3 of 4 Old 07-18-2005, 06:13 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
RMS and Dynamic have nothing to do with how it is being powered. RMS is the amount of power it can put out continually under a certain threshold limit of distortion.
Dynamic power is kind of like Peak power that it can put out for brief loud passages or things like bass notes or the temporarily loud peak dynamics of a band or singer. It's kind of like running a sprint vs. running a marathon... amps can put out more peak dynamic power for musical peaks than they can sustained RMS power.
RMS and Peak is also how power from a signal is measured... RMS is a more conservative measurement, peak and peak-to-peak are measured using more of the waveform.
Like "Music Power" and "Peak Power" are both kind of misleading terms used by some equipment manufacturers or retailers to boost an amplifier's wattage ratings as much as possible to make the amplifier seem more powerful than it really is. Using the RMS power to compare between amplifiers is really the only way to compare power on an apples-to-apples basis.
Gone on vacation until August 25.
Jerry Bransford is offline
post #4 of 4 Old 07-18-2005, 06:21 PM
kappaknight
Oops, read that wrong... I thought both said RMS
Power Outlet on 06LJ has no power HELP! 90SaharaJeep Audio, CB & Ham Radios, GPS, & Electrical 8 04-23-2009 06:46 PM
Power Windows and Power Locks? Broadbent Audio, CB & Ham Radios, GPS, & Electrical 6 03-13-2009 07:31 PM
Power output of stock radio? DRM-2000 Audio, CB & Ham Radios, GPS, & Electrical 1 11-12-2008 03:31 PM
What about winch power in, and power out feature? CB3 General Jeep & Off-Road Equipment 27 06-05-2008 02:29 PM
Stock AM/FM cassette power output? Bob K Audio, CB & Ham Radios, GPS, & Electrical 1 11-09-2003 04:31 PM
