aftermarket upgrade issues - JeepForum.com
post #1 of 2 Old 02-13-2013, 08:29 PM Thread Starter
03wjay
2003 WJ
I have replaced the factory amp with a RE 4 channel and a NVXhi low converter. The issue is that one of the rear door and dash speakers dosnt work. by switching out rca's you can change it from left to right. this makes me think everything has power but not getting input. tried different rcas with same result.
any ideas?
03wjay is offline
post #2 of 2 Old 02-13-2013, 11:00 PM
MyKeyB
Sounds like you have power to the amp and speakers. Either the converter is bad or one side is not getting a signal. Recheck the connections on the side that's not working going to the radio's speaker lead and if it has a gain control try turning it up.
MyKeyB is offline
