Aftermarket Remote Starter question - JeepForum.com
post #1 of 5 Old 01-11-2012, 06:12 PM Thread Starter
sixfoot9psu
2005 WK
Hey everybody, just bought my first jeep a couple weeks ago and i found this under the hood:
i think it's part of the aftermarket remote starter? this picture shows where the cable connects to the hood. is it just the ground wire or does it have another purpose??? I've never seen a wire run like this up to the hood on a stock vehicle which is why i assume it's the remote starter bc that's the only aftermarket thing that the vehicle has. I've started to have an electrical problem and i figure it's bc this connection is all corroded? Can i just take it off and clean it with a steel brush, let it sit in a cup of coke and then reinstall with new screws? (i've read soaking battery cables in coke for 30 min helps?) My electrical problem is this: if my jeep has been sitting for awhile and i go to start it up and the headlights/fogs are on auto and it's dark enough out for them to be on, i get a grinding sound like the starter isn't engaging the flywheel correctly. Like the headlights are drawing too much juice to allow the starter to work correctly. Do you think fixing that corrosion problem would solve the starter/flywheel problem? Thanks!
Edit: it only makes the grinding noise if all the lights are on
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline
post #2 of 5 Old 01-12-2012, 03:51 AM
Photog2000
It looks like a mercury, or some sort of gravity switch that disables the remote start when the hood is open so it cant be accidentally be activated while a tech is under the hood. I would guess it is sealed and soaking it will only do further damage if it is faulty.
Photog2000 is offline
post #3 of 5 Old 01-12-2012, 08:46 AM Thread Starter
sixfoot9psu
2005 WK
Interesting, I'll have to try starting it with the hood open to see if that's the case...maybe I'll just clean it up best I can with a steel brush and replace the screws and see if that helps...thanks for the advice bc I was about too soak it! And would have prob ruined it!
post #4 of 5 Old 01-12-2012, 10:56 AM
Indy
Indy's Avatar
That will have absolutely nothing to do with your problems. Assuming its a mercury switch all it does is tell the remote starter to not start while the hood is up. But looking at it, good guess your grounds are in similar condition.
I'm the only gay eskimo.
Indy is offline
post #5 of 5 Old 01-12-2012, 08:29 PM
Photog2000
That would be my guess as well. As I stated above, it is most likely a sealed unit and cleaning the outside will do nothing to help you.
Remote starter w/Manual Trans Question Skyryder Audio, CB & Ham Radios, GPS, & Electrical 7 11-11-2010 03:26 PM
Remote starter help please! mahoot207 Audio, CB & Ham Radios, GPS, & Electrical 17 11-18-2009 11:10 AM
Remote Starter jcollins Audio, CB & Ham Radios, GPS, & Electrical 3 04-05-2006 01:41 PM
Remote starter coloradocj-7 Engines & Drivetrain 5 12-20-2004 08:23 PM
remote starter? 98TJSport Audio, CB & Ham Radios, GPS, & Electrical 9 11-22-2004 06:15 PM
