Aftermarket fog light install write up?
#1 | |
Hi all -
I am an electrical noob. I have a 2002 TJ that is not prewired for fog lights. I have a set of Hella 500 fogs that I want to install. I have done multiple searches on the forum and online for a step-by-step write up with no luck. I understand the standard JF diagram for light hookups but I need a little more help than that. Pics of actual hookups would help me. does anyone know of a stepwise writeup with pics? I'm talking like "wire A goes here" (insert pic), "wire B goes here" (insert pic) kind of stuff. you would think a really simple, explicit writeup would cut down questions about fog light hookups. thanks-med
2002 red TJ 2.5L 4 cyl; 31x10.5 Firestone Destinations; JKS Quick Discos; stock suspension |
#2 |
Maybe try the Hella website...
One step beyond................ |
#3 |
Go Jeepin
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#4 |
Thanks. The Hella diagram and the above diagram offered is helpful. however, i'm still looking for pictures of the wires routed and installed in an actual jeep, how the grounds are hooked up, etc. thanks again though. med
#5 |
So I found something online similar to what I was looking for. Might also help someone else if they do a search and find this thread. The guy on myjeeptj.com has a write up install with pictures of an actual jeep that is helpful. When I get around to installing mine (and if it works) i'll try to take detailed pictures and post.
Here's the link to his writeup. sure he won't mind. http://myjeeptj.com/2008/05/21/kc-daylighter-150w-sealed-beam
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
