adding a sub in the factory sub spot - JeepForum.com
post #1 of 15 Old 08-10-2004, 08:14 AM Thread Starter
vballman
hey guys!
I just got a 03 TJ sport. I am very excited. Wanted a jeep for a while. anyways, it came with the 4 speaker set up. I am working on replacing the speakers. But i want to add a sub in the factory slot. i believe it is an 8" sub. where is a good spot to wire this up and what is the best way to run the wires.
thanks!
vballman is offline
post #2 of 15 Old 08-10-2004, 08:19 AM
SirGCal
RIP
SirGCal's Avatar
The factory sub is a 6" sub in the center console. You can run the wires down the center from the dash under the console or down the drivers side and under the driver's seat.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 15 Old 08-10-2004, 08:22 AM Thread Starter
vballman
where is a good spot to put an amp? any idea who makes a 6" sub?
vballman is offline
post #4 of 15 Old 08-10-2004, 12:19 PM
SirGCal
RIP
SirGCal's Avatar
JL makes probably the best 6" sub that I can think of off the top of my head... Kicker makes one too but it's more of a mid-bass driver than a sub. Still good though. Rockford used to make one.
put the amp under a seat or under the dash if you have the room. The JL sub only needs 75W so that sub would be quite small and you could probably shoe-horn it in anywhere. Even if you moved up to a good 8" sub, they aren't going to eat more than 100W (for any of them that would run in that small of a box anyhow...) The hard part is going to be finding an amp that will run that low into a mono load. Your best bet is going to be to look for a small 2-channel bridgable amp. (something that is 20Wx2@4 ohms would be close (which would be about 80Wx1@4 ohms))
SirGCal is offline
post #5 of 15 Old 08-10-2004, 12:24 PM
SirGCal
RIP
SirGCal's Avatar
Something that might be easier and sound a little better is an RF P18S4 (8" stage 1 punch) which can handle 150W and only needs up to .35 ft^3 sealed and an Alpine MRP-T220 (140Wx1@4 ohms) amp.
Small amp and small sub requirements with good matching power. The amp also has speaker-level inputs incase you are going to use the factory head unit. (you don't need a line-output converter to run RCA's)
SirGCal is offline
post #6 of 15 Old 08-10-2004, 01:00 PM Thread Starter
vballman
For now I am giong to use the stock head unit. I want to replace all the speakers first and add the sub. i have a small pioneer amp that might work as well. does changing it to an 8" make a lot of difference in how it is mounted?
vballman is offline
post #7 of 15 Old 08-10-2004, 01:27 PM
SirGCal
RIP
SirGCal's Avatar
The process is the same (build an enclosure for it), the only difference is that the enclosure will be slightly larger (.35 ft^3 instead of .2 ft^3 in the case of the RF 8" and JL 6). You will still need to build the box. I'd use 5/8" MDF for most of it and maybe fiberglass for the area around the e-break.
Here's a link to someone who already made the console box for an 8" and he has most of the measurements up there.
http://community.webshots.com/album/63423573sSraTy
SirGCal is offline
post #8 of 15 Old 08-10-2004, 01:56 PM Thread Starter
vballman
would it be easier to find a factory set up and just replace the sub?
vballman is offline
post #9 of 15 Old 08-10-2004, 02:24 PM
SirGCal
RIP
SirGCal's Avatar
It would be easier, but wouldn't sound near as good. The factory is also only 6" so your stuck there. It's also a DVC and I don't know what the stats are on the factory amp so that part might even be harder... The factory box is plastic though and not worth upgrading. Since your starting from scratch, I'd try to build it up. If you just want to go with a factory type setup, then just get an all-factory system and be done with it. (factory amp, sub and box)
SirGCal is offline
post #10 of 15 Old 08-10-2004, 08:39 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
just for a couple ideas:
http://www.jeepforum.com/forum/f20/upgraded-factory-system-pics-88858/
I went with the Rockford Fosgate 6.5" sub in the factory enclosure and bridged a small 2-channel amp to power it...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #11 of 15 Old 09-13-2004, 01:56 PM Thread Starter
vballman
well i got a factory sub for it. what i am doing now is replacing it with a JL audio sub. I have to modify the box some to get it to fit but i am almost done with that.
vballman is offline
post #12 of 15 Old 09-21-2004, 10:32 AM Thread Starter
vballman
any suggestions on where i can hide an amp under the dash?
vballman is offline
post #13 of 15 Old 09-21-2004, 06:19 PM
SirGCal
RIP
SirGCal's Avatar
If you don't have tilt-wheel, some people have had luck with smaller amps and custom mounting bracketry on the driver's side next to the steering column.
SirGCal is offline
post #14 of 15 Old 09-22-2004, 06:17 AM Thread Starter
vballman
ah that stinks, i do have a tilt wheel. i still may have to check it out. any other suggestions?
vballman is offline
post #15 of 15 Old 09-22-2004, 07:21 AM
SirGCal
RIP
SirGCal's Avatar
Get the smallest physical sized amps you can... The smaller, the better.
SirGCal is offline
Adding an amp to a factory HU TheMike Audio, CB & Ham Radios, GPS, & Electrical 5 07-07-2009 02:02 PM
Adding relays to factory box? HomeSpun Audio, CB & Ham Radios, GPS, & Electrical 2 12-17-2007 08:32 AM
Adding factory fog lights... Steelman Audio, CB & Ham Radios, GPS, & Electrical 2 06-02-2006 08:21 AM
Adding a Factory Subwoofer? jcd Audio, CB & Ham Radios, GPS, & Electrical 6 05-22-2006 10:45 PM
Adding amp to factory system COwheeler Audio, CB & Ham Radios, GPS, & Electrical 6 04-13-2005 09:58 PM
