Adding a second battery - JeepForum.com
post #1 of 7 Old 10-21-2013, 07:57 PM Thread Starter
kylebeau
I just had a quick question and maybe someone can help me. So my idea was hooking up a second battery to my yj and then adding a kill switch to the second battery so I can only use when I need it and then turn it on in case I need to jump it and then I can kind of "self jump" it. My question is is that possible and how would I go about doing it.
kylebeau is offline
post #2 of 7 Old 10-23-2013, 09:37 AM
Indy
Indy's Avatar
Google dual battery isolator
I'm the only gay eskimo.
Indy is offline
post #3 of 7 Old 10-24-2013, 05:43 PM
HappyTrails
Something like this: http://www.quadratec.com/products/17004_200.htm
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #4 of 7 Old 10-24-2013, 05:51 PM Thread Starter
kylebeau
Anything cheaper maybe?
kylebeau is offline
post #5 of 7 Old 10-24-2013, 08:24 PM
Indy
Indy's Avatar
Buy a set of jumper cables, $10.
Indy is offline
post #6 of 7 Old 10-24-2013, 08:56 PM Thread Starter
kylebeau
hahaha true
kylebeau is offline
post #7 of 7 Old 10-25-2013, 01:25 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
get a properly rated solenoid and mount it near the aux batt. run a switch to the dash. energize solenoid from te aux batt. when engaged, they run is parallel. switch off, its isolated. use properly rated welding cable and lugs plus leave slack for engine flex.
this sort of shows what i mean and how i set up mine
edit: well not really. got the solenoid from wrangler NW power products. manual switching on/off is a good thing. others use a tap into the oil pressure to energize aug charging circuit, but i like the fully manual option.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
