#1 | |
Hmmmm....
Adding Fog Lamps to a GC
I'm getting a 1996 Jeep Grand Cherokee soon, it has many features, but unfortunately lacks Fog Lights. In my area, it gets incredibly foggy at times and I would like to install Fog Lights. The question is, which ones should I choose to use, and is there any special installation instructions since they are not standard on the Jeep I'm getting?
#2 |
We aren't building a Space Shuttle... pick a design you like. Make sure it is a Fog Light Design, can be either Yellow or White light ( I like the Yellow for Fog ). You can buy a kit with harness or a separate harness rated for your lights, just make sure to get one that is for your vehicle. Read the instructions and install lights. By buying a pre-made harness designed for your vehicle, the install should be straight forward and even a plug-in in some cases. Make sure you get a good ground to a point where you have bare metal. Some people even run a separate ground wire if there isn't one already there. Luck,
Scrambler82 Do it right the first time ! |
#3 |
Hmmmm....
Do you any suggestions on brands/models that would look good on my '96 GC?
#4 |
I like the Hella 550 fog lights with amber lenses. They're as good as, or better than, any fog light I've seen.
#5 |
I have KC's Fogs to install but haven't seem them turned on to tell you exactly how they are.
Hella makes a good light too, there on the best of vehicles. I think that anything is better than nothing and cost will be the main gating factor here. I would start by finding something you like the looks of, get a set and try them out. Sorry I am not really up on different manufacturer's of Lighting, I usually do as I suggested "get'um, put'um on, see'um". ltr
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
