Quantcast Accessory Power Interupt/Switch Questions... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Accessory Power Interupt/Switch Questions...
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 11-18-2009, 12:21 AM   #1
RaggedOleMan
Student of Jeep stuff...
RaggedOleMan's Avatar
I have an 05-Tj. I added an auxilliary fuse box identical to the factory one and installed it on the drivers side to use for my accessory fuses and relays. To do this I cannibalized the bone yard fuse box and used it to house the new aftermarket relays and fuses.
I run a Warn M8000 through the 12Volt Guy's interior/dash switch set up, (2) KC Daylighters, (2) 55 watt undercarriage lights, (2) 55watt rear/back-up lights and a CB off the bone yard fuse box. I supply the auxilliary/bone yard fuse box with power direct from the battery via a fused (40amp) 8g feed. I solder all my connections.
This set up feeds power to the 12Volt Guy's Tj Winch Switch which is wired per his installation instrcutions and the winch itself is wired directly to the battery per the manufacturere's (Warn) instructions.
Here's my problem: Upon returning from a week's vacation WITHOUT MY JEEP the 2-year old Red Top Otpima wouldn't turn over the motor so I had to jump it. That leads me to believe that the battery is being discharged while at rest and/or the alternator isn't up to its job? Is that correct?
If that's true, then as far as I know I can either replace the alternator and/or install some sort of switch to isolate my accessory fuse box from the battery when I want to. So that's where I'm not clear. I don't necesarilly want to cut off ALL power (master battery switch) when the Jeep is at rest i.e. the clock would always be wrong but I do want to shut off or limit the power draw from the auxilliary fuse box when the Jeep is at rest. Can/will someone please tell me what my options are and/or some suggestions?
Thanks,
~jL
Seattle
RaggedOleMan is offline   Reply With Quote
Old 11-18-2009, 12:50 AM   #2
Rgrgoog
I have on of these in my Jeep. Called a Battery brain and it cuts the power so you will always have enough juice to start your engine.
Battery Brain + Our Products + Type IV for Utility Batteries
Rgrgoog is offline   Reply With Quote
Old 11-18-2009, 03:12 AM   #3
madrabbitt
Battery cut off switch, with a "keep alive" jumper.
Basically, you have a master battery disconnect, with a low amp wire bypassing it. The wire has some type of circuit limiting the amperage thru it. Its enough to keep your computer and clock memories intact, but not enough to allow a parasitic draw to drain the battery.
Easiest way is to install a battery cut off switch, and run a wire across it, with a 10 amp, self resetting circuit breaker. That will allow current up to 10 amps to run thru it when the battery is disconnected, protecting the electronics, but preventing a major drain on the battery.
You can either wire it early enough in the system that it cuts the battery off from ALL the jeep's electrical system, or further upstream where it only cuts off your secondary fuse box.
Doing it the first way, it would also be an effective anti-theft device, especially if you use a keyed switch. Any attempt to start the jeep, either by ignition, or by hotwiring, would cause the breaker to trip.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 11-18-2009, 08:10 PM   #4
RaggedOleMan
While the Battery Brain sounded hopeful, the reviews on the Bronze & Silver Battery Brain left a bit to be desired. That said, I'm inclined to go with the Master Batterry Disconnect with a jumper. Tell me, where do I get a self resetting circuit breaker? Not sure I've ever heard of that...forgive me, but, it doesn't make sense! Self resetting circuit breaker? Help me out here...do they make one for an x-wife, too?
Respectfully,
~jL
Old 11-18-2009, 08:22 PM   #5
madrabbitt
Actually, they're very common in vehicles.
Look in your fuse box, anything that looks like a big metal fuse is probably a self-reset breaker.
ATC Circuit Breakers
Type 2, 10 amp on that page will work for you.
They also sell a battery cut off switch and the wiring that you need to complete it.
Old 11-19-2009, 11:52 AM   #6
RaggedOleMan
Thanks!
Well, now I feel a bit foolish! Thanks to RgrGOOG and MadRabbit, genuinely...I'll do the master disconnect + jumper with the fused/self resetting circuit breaker! Thanks again, guys, your help was invaluable...and thanks to the Forum, too. For without the Forum some of us would be lost...
~jL
Seattle/Tacoma
Old 11-19-2009, 02:06 PM   #7
madrabbitt
let me know if you need any guidance wiring it.
i've probably done enough of them in fleet vehicles, that i could do it with my eyes closed.
Old 11-19-2009, 04:17 PM   #8
RARECJ8
here is how i have the heep laid out. at front is the OBA manifold and pressure gauge. then behind that is a master kill high amp switch on the hot lead to the Warn 8274 and next is a Blue Sea Systems Aux power kill switch that engages/disables the aux blade fuse panel just behind that. Hope this helps-- the Blue Sea switch kills all Aux power systems but the EFI computer, etc are always energized thru the primary power system.. It's nice to know i can kill all aux circuits with a simple twist.
here is a link to more than you can ever use. Good Luck!
http://bluesea.com/category/1
Life member BRC
Cal4Wheel
www.hillsangels4x4.com
RARECJ8 is offline   Reply With Quote
Old 11-19-2009, 04:34 PM   #9
madrabbitt
really really nice and clean there.
Glock Forum
