96 ZJ Floor light won't turn off. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & HAM Radios, GPS, & Electrical. > 96 ZJ Floor light won't turn off.
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 06-04-2013, 09:40 PM   #1
96zjSORT
The light just above the brake pedal doesn't shut off when the car is turned off. I thought it would go off after a few minutes but I was at work for 8 hours and it was still on. I don't think I can pull a fuse without turning other things off. Anyone know how to disable it? Thanks.
96zjSORT is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 04:56 AM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Remove the light bulb.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 04:50 AM   #3
4x4fun
If you have the push button switches in the door frame you might want to check and see if it is shorting out on its self
4x4fun is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 04:53 AM   #4
4x4fun
Or it my be shorting to ground at another point but start at the switch and trace it back till you find the short
zj
