94 YJ electrical issues after Chevy 350 swap - JeepForum.com
post #1 of 6 Old 09-11-2011, 12:33 PM Thread Starter
JeepDrew_94
I've got a 94 YJ that i've had back from getting a Chevy 350 and ax15 installed for about a week now. The motor is carbed. None of my stock gauges are working but the aftermarket guages that were installed for the voltage, oil psi and radiator temp gauge work. What could be the problem?
JeepDrew_94 is offline
post #2 of 6 Old 09-19-2011, 06:54 AM Thread Starter
JeepDrew_94
Anyone have any idea what could be going on?
post #3 of 6 Old 10-03-2011, 12:24 PM Thread Starter
JeepDrew_94
anyone? still not having any luck and my mechanic is hard to get in touch with
post #4 of 6 Old 10-05-2011, 05:28 PM
neonhomer
Odds are they were not hooked up. When the original motor was removed, the PCM was probably removed, which is were some vehicles get their gauge data from. I know that my 94 Caravan has two computers, the PCM for the engine and a BCM for the gauges and interior.
If they didn't hook up the speed sensor to the new transmission, there will be nothing to read. Fuel level is also read from the BCM.
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #5 of 6 Old 10-05-2011, 08:56 PM
mylt1
mylt1's Avatar
build a custom dash section and install all aftermarket gauges. then they will all work.
mylt1 is offline
post #6 of 6 Old 10-06-2011, 11:38 PM
SnowdogMarc
I just did a 98 4.3 swap into my 88 and all the factory gauges work with the new motor with the exception of the tach I had to swap out. I just replaced the Chevy oil sender with the one from my 2.5 and no problems, didn't have to put in aftermarket ones but if one set is working and the others are not they probably didn't add a second set of pickups for the OP or Temp.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
Chevy 454 swap blacksheepjp Engines & Drivetrain 15 05-17-2011 04:34 PM
85 CJ with 91 Chevy 350, electrical problems pga216 Engines & Drivetrain 0 11-15-2009 06:05 PM
Who has done a 4.3 Chevy swap? danholovic Engines & Drivetrain 2 10-29-2008 08:41 PM
chevy 4.3 swap lurkeryj Engines & Drivetrain 2 04-28-2008 10:08 PM
Chevy V6 swap Grey4.0L Street Jeep Forum 2 11-20-2007 04:30 AM
