94 XJ 4.0 HO TPS error code 24 HELP - JeepForum.com
post #1 of 2 Old 08-06-2011, 03:21 PM Thread Starter
oregonxjcrawler
1994 XJ Cherokee
Hello,
I really need your help. My XJ is having some wierd issue and I can't seem to readily fix it. Here is the Story -
XJ starts , idles, and runs great when cold - After about 40mins to 1 hour of driving it starts idling all rough, then cuts out at accelleration and check engine light comes on saying error code 24.
I replaced the TPS twice but still same thing happens / I replaced the MAP sensor Still no improvement. Then I even bought a New ECM for it - still same problem persists.
All I can think is the wireing harness between computer and TPS is somehow getting hot and malfunctioning. PLEASE HELP!!!
Any suggestions are much appreciated
oregonxjcrawler is offline
post #2 of 2 Old 08-07-2011, 01:23 PM Thread Starter
oregonxjcrawler
1994 XJ Cherokee
Please Jeep friends - I really need some input here - has anyone had this happen ?? or does anyone have any idea what could fix this!!!!
cherokee , MAP sensor , stalls , tps
Had trans code for range sensor, replaced neutral safety switch and still have code 97sportxj Engines & Drivetrain 6 12-08-2010 04:33 PM
Error code P0420 and P0423 can you help! Zingnut Engines & Drivetrain 0 09-02-2010 01:17 PM
help with this error code please jeepster1900 Engines & Drivetrain 3 11-12-2009 11:04 PM
Need Help with Grand Cherokee MIL error code nipsnertz Engines & Drivetrain 7 06-29-2009 12:02 PM
Error Code 51, I've got it PolloLoco Engines & Drivetrain 0 12-14-2006 01:12 AM
