92 Cherokee Automatic straight 6 pain in the a** - JeepForum.com
post #1 of 4 Old 12-28-2013, 11:11 PM Thread Starter
JeeperJeep12
1992 FSJ Cherokee
I am having a hard time getting it started. I turn the ignition switch and everything kicks on but it won't turn over. I put it in nuetral and try starting it. Onve again everything kicks on but it doesn't turn over. If I turn the ignition switch and hold it in place for what seems like forever it will turn over... but it will only do it is in neutral not park. Is it the ignition switch or a relay?
JeeperJeep12 is offline
post #2 of 4 Old 12-29-2013, 03:19 PM
jeepcicle
You should be able to pull off the driver lower dash and access the plug for the ignition switch. If you measure the voltage with the key in the acc-off-on-start positions you should be able to build a chart that shows you have a constant power wires (12V in all positions), a constant ground, an accessory (12v in ACC and ON), a start (12V in START), and an Ignition 1 (12V in ON and START), there may be an Ignition 2 ( 12V in ACC, ON, and START).
You want to make sure your Start wire is working and Ignition 1, if either of these doesn't have 12V your vehicle will not start. If Ignition 1 doesn't have power the vehicle will not run or start, so most likely it is something with the start wire. If your ignition switch is bad the voltage on the wire won't be there.
The attached image shows the wires you should expect although it is from a 90 Cherokee so the colors may be different. The dark green is your start wire and yellow ignition 1 on the diagram. Hopefully your jeep's wires are the same color. Let me know how you make out.
jeepcicle is offline
post #3 of 4 Old 12-29-2013, 03:54 PM Thread Starter
JeeperJeep12
1992 FSJ Cherokee
Found out the problem. The switch in the shifter is of. When the shifter is in park, you have to push it forward a bit and then turn the ignition switch. Then it starts. My dad told him he bumped the Cherokee the other night with his Wrangler and we think it might of shifted things..... we don't know for sure...
post #4 of 4 Old 12-29-2013, 04:20 PM
jeepcicle
Well that's a much easier fix!
