7 pin Trailer Connector for Wrangler - JeepForum.com
post #1 of 3 Old 10-25-2008, 08:09 AM Thread Starter
J-Mox
Tj 7 pin Trailer Connector for Wrangler
Does anyone know of a plug-in 7 pin for a 2004 Wrangler? I know that I could splice wires or get a 4 pin with adapter but I would prefer a complete plug in. And will one from a Liberty or GC have the same taillight plugs that I could buy one for that model and hook it to mine?
J-Mox is offline
post #2 of 3 Old 10-26-2008, 07:29 AM
SirGCal
SirGCal's Avatar
There is not going to be a plug-in kit I don't believe. Any kit like that is going to be splice for a wrangler. Or even more appropriately, running new wires all together and splicing in triggers. But I do not know of any kits to do this.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 3 Old 12-23-2008, 11:05 AM
Grt_Ape
Jeeps Are Us sells the OEM 4- and 7-pin harness that plugs right in to 1997 - 2008 Wranglers.
The 7-pin harness was an option for the Unlimited models and should plug right in. You will have excess wiring if used in a SWB wrangler, which you can shorten or loop and secure. I would assume they didn't offer the 7-pin as a SWB option due to the shorter wheelbase limiting the rated tow capabilities.
Select the Unlimited Model, and your year Wrangler (changes from pass side to driver side). $75 plus shipping.
Here you go:
http://www.jeepsareus.com/Merchant2/..._Code=Wranger3
Chris
2006 LJ Rubicon
Grt_Ape is offline
10 pin connector Jocko12 Audio, CB & Ham Radios, GPS, & Electrical 2 10-11-2009 10:11 PM
Build Trailer Using Trailer House Axles?? jsc7002 Fabrication Shop 5 07-19-2009 06:43 PM
help installing PL-259 connector willyb8 Audio, CB & Ham Radios, GPS, & Electrical 6 03-04-2009 03:46 PM
XJ Bulkhead Connector mxracer513 Street Jeep Forum 1 06-09-2008 09:27 AM
Trailer lights issue after installed T-connector General Lee Audio, CB & Ham Radios, GPS, & Electrical 9 10-24-2005 08:52 AM
