6.5" component setup - JeepForum.com
post #1 of 4 Old 06-18-2013, 11:10 PM Thread Starter
kjmccar
How can I install 6.5" component speakers in my TJ? I would like something that has precut holes and mounts to the roll bar in place of the current ones.
I purchased JBL MS-62C speakers to replace my current C2-650 (coaxial) which I just bolted into the factory 5.25" enclosures. The sound was not too great, and when one of the C2 speakers crapped out I decided to go for JBL because the JBL speakers in my Mom's Prius sound great.
Since I am upgrading I would like to get an enclosure that will resonate with the 6.5" speakers for best sound. What options are available? I would like to keep it under $100... If that is possible.
Thank you.
kjmccar is offline
post #2 of 4 Old 06-19-2013, 06:28 AM
kingcat400
they will mount in you stock sound bar/sound pods without cutting. also fill the pods/bar with poly fill but not packed in.
what do you have for dash speakers? do you have an amp?
normaly running a component set in the sound bar is not a good idea. most stick with a coax. were do you plan on mounting the tweeter? you will also need a place to mount the crossover.
kingcat400 is offline
post #3 of 4 Old 06-19-2013, 09:01 AM Thread Starter
kjmccar
I'm currently running 6.5" coax in the factory setup, but I want to upgrade. I was hoping to purchase a soundbar/enclosure that had a tweeter option - and mount the crossover in the enclosure.
I'm running JL C2-525x in the dash as of now, but if I am as happy with JBL I might get another set of the MS-62C and try to get them in there. I have an amp now, but I just purchased the JBL GTO-804EZ amp so I have the option to run my 80watt speakers at full power.
kjmccar is offline
post #4 of 4 Old 06-20-2013, 12:41 PM
gily25
I see you have 2 threads now for this subject. If you are going with 6.5" comps for midbass you'd be better off to try to incorporate a sub somewhere. Also look into adding an amp behind the speakers which will allow you to keep the volume lower and give better SQ.
iPhone app user; excuse typos...thanx.
gily25 is offline
