5 130W Offroading lights mounted on roof, how do i wire? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > 5 130W Offroading lights mounted on roof, how do i wire?
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 06-24-2012, 09:53 PM   #1
troyhazard
Hey guys, I just mounted my 5 Offroading lights on my rack. They are 130 watts. Ive been searching and cant find anywhere that explains how to do it with what i have to wire. How did I wire them up? Thanks in advance!
- 2004 WJ, tinted front and rear lights, blacked out grille, Sound system, suspension currently stock but will be transformed into a beast within the month.
- 1988 XJ, Sold for $4,900 with over 300,000 miles, lots of mods.
troyhazard is offline   Reply With Quote
Unread 06-25-2012, 06:24 AM   #2
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
Maybe this helps.
I would get two 40A or 50A relay so that you can have 3 lights on one relay and 2 lights on the other relay.
Its never a good idea to max out the load on the relay.
One 130w light = 10A
For example you have a 30A relay and 3 130w= 30A relay will kill itself.
A 30A relay and 3 100w lights = 25A (you will do just fine with a 30A relay here)
Pierre_r is offline   Reply With Quote
Unread 06-25-2012, 07:37 AM   #3
chriskeenan
Not Involved
chriskeenan's Avatar
also with that much power draw make sure the wires are sized correctly.
http://www.engineeringtoolbox.com/am...uge-d_730.html
chriskeenan is online now   Reply With Quote
Unread 06-25-2012, 08:13 AM   #4
Ross
Originally Posted by Pierre_r View Post
Maybe this helps.
I would want a seperate switch for each set (of two).
Schitzangiggles: We used to teach our children to fight evil, now we teach them that fighting is evil.
2001 TJ, 33 trxus MTs , W, locked, belly up, some armor.
"If you aim at nothing, you will hit it every time." Zig Ziglar
Ross is online now   Reply With Quote
Unread 06-25-2012, 08:21 AM   #5
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
Easy just do this:
One thing that is not in that drawing is a fuse.
If it is 30A relay use a 30Afuse as close to the battery as possible
Unread 06-25-2012, 02:21 PM   #6
troyhazard
Thanks guys! So do I put the fuse on the wire going from the switch to the battery or The battery to the relays? And do I have to do 2 switches or can I get away with one? Thanks!
Unread 06-25-2012, 02:31 PM   #7
Ross
battery to relay
Unread 06-25-2012, 02:37 PM   #8
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
The fuse is normaly on the wire between the battery and relay.
But if you want extra security you can put a fuse on the + wire to the switch.
You can have 1 switch like in the first drawing i posted.
Just splice together (or solder) the 2 wires that are connected to post nr:86 on the relays and then to the switch.
Unread 06-25-2012, 07:05 PM   #9
troyhazard
Sweet thank you! I went to the auto parts store, radio shack and hardware store and none of them had the stuff I needed besides the wire haha. So I guess I'll buy the stuff online and try it then. Thanks for your help! I attached a picture of the lights on my WJ! Excited to take it wheeling in the night once I get them hooked up!
Unread 06-26-2012, 09:58 AM   #10
Xpress
Xpress's Avatar
I bought this pack of Relays a while back and they work great. Have only used a few of them, sofar all is working great. And you can't beat the price.
http://www.amazon.com/AGT-Relay-Harn...s=relay+5+pack
You will be running very close to 30 amps with a set of 3, 130w lights, but you should be fine. 40 amp burst, you will need to run 30 amp fuses.
Then all you need is a couple of in line fuse sockets:
http://www.amazon.com/In-line-ACT-Wa...s=in+line+fuse
And the fuses themselves:
http://www.amazon.com/Littelfuse-009...ords=fuse+pack
Always carry plenty of fuses. I keep that pack in my Jeep.
Then of course a soldering iron, rosin core solder, heat shrink tubing, and a basic understanding of how to put it all together. Wire loom makes everything look clean..
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-2004 Kawasaki KLR650
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
L.E.D. Guru
Xpress is offline   Reply With Quote
Unread 06-26-2012, 10:35 AM   #11
chriskeenan
Not Involved
also, these are the shiznit when it comes to connectors, we use them at work and there great, wee bit pricy though.
http://www.fastenal.com/web/search/product/electrical/terminals..
Strip and crimp, then take a heat gun to melt the solder pellet and seal the connector
Unread 06-26-2012, 12:28 PM   #12
troyhazard
Thanks I will have to order those parts today. With the relay being 5 prong do I just leave one of them unattached??
Unread 06-26-2012, 12:40 PM   #13
chriskeenan
Not Involved
One is a NC (normally closed) contact, the other is NC (normally open), so if the coil is energized or not one contact will have a complete circuit, it useful is you want to interrupt a circuit when the relay is on. Some relays are different, but most will be this way, check them if you not sure.
Unread 06-26-2012, 01:07 PM   #14
Xpress
Xpress's Avatar
Like mentioned the 87A prong will constantly be energized so long as the power is hooked to the 30 prong. Just unhook the pin from the socket if you don't want to use it.
L.E.D. Guru
Unread 08-15-2012, 03:18 AM   #15
troyhazard
Hey guys thanks for the help, I got them all hooked up, I attached a couple pics so you guys can see, thanks again!
