4"x6" Speaker Replacement - Page 3 - JeepForum.com
post #31 of 45 Old 03-20-2005, 08:27 AM
RescuedJK
dude I can get you diamond audio replacements that are going to be better than any other speaker out there at the same price off the top of my head I can do prolly do front 4x6's and rear 5.25's for like under $250 these are some of the best in the market and would compare to alpines type R components and fosgates upper line speakers, and so on and so forth just let me know!!!
RescuedJK is offline
post #32 of 45 Old 03-20-2005, 08:35 AM
capecodtjeep
BTW, you won't get any bass out of 4x6. Just mid's and high's. I say definitely get 5 1/4". I had my 4x6's just laying around. I would much rather have 5 1/4". Generally speaking, bigger is better w/speakers. Try and match "RMS" and "Ohms" to your head unit. High price definitely won't insure good sound quality.
capecodtjeep is offline
post #33 of 45 Old 03-20-2005, 09:50 AM
Lud04X
Got a reccomendations for speakers front and rear (that don't cot too much) for use with a factory stereo?
I have a CD unit and I really don't want to replace it if I don't have to but it feels like a lot of sound is missing from my music and the front vibrate the dash like crazy with any amount of Bass.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #34 of 45 Old 03-20-2005, 09:54 AM
Red Rubycon
Red Rubycon's Avatar
Not to Hijack thread (well, just a little bit). I have infinity reference 5-1/4 in front and 6-1/2 in the back (sound pods) of my rubi. The head is an alpine, the kind with the automatic retracting face plate. I want a small, small subwoofer to get rid of the tin can sound I have now. Both clarion and jenson make small self contained units that would fit under the front seat. D/N want basslink or bazzoka or an amp. What do you suggest?
Red Rubycon is offline
post #35 of 45 Old 03-20-2005, 10:40 AM
2k3r1
2k3r1's Avatar
first i am going to disagree with the component speaker remark earlier. Jeeps are loud and most of the clarity that the components have will be lost. Kinda a waste of money. ESPECIALLY if you have a soft top or drive with your top off.
Also if you get 5 1/4" speakers in the front then get the EXACT same speakers for the sound bar. Voice matching
2000 TJ Sport, 4.0L, 5-spd, RE 3.5" with all 8 adj arms and adj trackbars with 35"s, D30 w/ Lockright, 8.8 rear axle, sye and CV driveshaft, M.O.R.E. 1" BL and MML, IPF headlights w/ H4 FATBOY bulbs, PSC power steering skid, rock-it man rockers, uniden pro 520xl WITH PA :)
Future mods: 4.88s and ARBs?, belly up, dif guards, Gastank Skid.
2k3r1 is offline
post #36 of 45 Old 03-20-2005, 11:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Right after you describe how "Jeeps are loud and most of the clarity that the components have will be lost", you then suggest that the sound bar speakers must be the "EXACT" same speaker as was installed up front for voice matching?
Jerry Bransford is offline
post #37 of 45 Old 03-20-2005, 11:40 AM
capecodtjeep
I guess it's a matter of money. Component speakers are not a "waste of money", in my opinion. I just like to turn it up loud w/out a popping sound.
post #38 of 45 Old 03-20-2005, 11:59 AM
SpeedJeep
SpeedJeep's Avatar
Most of the extra power handling comes from the wattage wasted (generating heat) in the crossovers. Very little of that extra power makes it to the speakers.
In fact, most PA speakers that are designed to be loud have no crossovers on the mids whatsoever. That popping sound comes from over excursion, something no component set alone can fix. Tweeters won't pop, they'll just die quickly and silently without some sort of passive crossover, and a simple capacitor can do that. An active crossover can fix that popping sound.
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #39 of 45 Old 03-20-2005, 12:21 PM
capecodtjeep
You say potato, I potato. You probably know more about it then I do. I guess Components are useless junk, whatever.
post #40 of 45 Old 03-20-2005, 05:36 PM
capecodtjeep
A component loudspeaker is a single driver designed to reproduce frequencies in a given range. Component speakers are used in tandem with other component speakers to reproduce the entire audio spectrum. As few as two and as many as four or more different size drivers can be used to create a component set. The drivers are kept operating within their designed audio band by a series of frequency filters known as a crossover. By using a crossover to keep speakers operating within a certain range the speakers do not become distorted by trying to reproduce frequencies that they are physically unable to reproduce
post #41 of 45 Old 03-20-2005, 06:17 PM
Red Rubycon
I've been loosely monitoring car audio for 10 years (I only know the basics though, it's not a passion of mine) and never heard of voice matching or having the same size speakers. Where is this coming from?
post #42 of 45 Old 03-20-2005, 07:42 PM
SpeedJeep
SpeedJeep's Avatar
Voice matching in a nutshell:
Every speaker has a "tone" or a voice". This means that two different speakers will never sound the same. You wouldn't expect a silk dome tweeter to have the same "voice" as a metal dome tweeter. Make sense? It makes equalizing the system easier if everything is the same even if you're just using the bass and treble controls on the head unit. If you use different speakers you might find that turning down the treble makes the front speakers sound better, but makes the back ones sound muffled and therefore you can never get the system to sound the way you like it.
Capecod,
I agree with your definition of components. What I disagree with is the reason you chose to use them: Volume
Do you agree that a coaxial speaker is actually 2 separate components but the tweeter is mounted on the same axis (pole) as the mid, hence the word "co-axial"?
I just hope you're not confusing the word components with separates as most people do.
You can easily add an outboard 12 or 18db passive crossover to a coaxial speaker and make a great sounding speaker as long as it is "on axis" with the listener. Most car speakers are not on axis with the listener.
*The reason to run separate components is for imaging, not volume.
Most 5.25 mids will play up to 12-15k before they naturally start attenuate the higher frequencies. Most distortion comes from a speaker trying to play frequencies that are too low, not from playing frequencies that are too high. So why would you put a 3.5-5k low pass crossover on them effectively cutting the frequency response by 2/3rds if you want volume? You don't. You apply the crossover hoping to get a better (flatter) frequency response.
*The reason for a passive crossover is to attenuate (IE: make not as loud) so your theory does not work here.
Remember, this is an open air vehicle like an amphi-theatre, not a quiet-as-a-church Lexus.
High pass crossovers protect speakers from over excursion, distortion, and that annoying "popping" sound you spoke of.
Low pass crossovers help create a flatter frequency response.
post #43 of 45 Old 03-21-2005, 03:46 PM Thread Starter
MCanavan
Capecod,
Wow that was confusing.
MCanavan is offline
post #44 of 45 Old 03-21-2005, 09:08 PM
BlueJ
Components are not junk depending on the brand. When properly amped a component speaker is freaking awesome sounding. I learned this in my last vehicle after I bought 4-way 6x9's.
1998 XJ Up Country - "The Green Chili"
BlueJ is offline
post #45 of 45 Old 03-26-2005, 06:06 PM
psl53
The the genral discussion forum Upstate Chili post a great pattern to make your own brackets to go from 4x6 to 51/4" round. I just finished and it worked great. Here is the link http://www.jeepforum.com/forum/f7/anyone-else-have-trouble-guy-148762/
Hope it helps
Out
Peter
99 Sahara 4.0 6 Cyl Auto White 4.5RE ATLAS II & TW shaft, BFG 33's, Jeeperman Rear bumper tire carrier, Rokmen Rockers, Warn M8000 Powertrax no-slip in front & Rear
psl53 is offline
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty Audio, CB & Ham Radios, GPS, & Electrical 6 03-05-2010 07:27 AM
Anybody know anything about 6 1/2" speaker box porting? bradyman1 Audio, CB & Ham Radios, GPS, & Electrical 5 05-30-2008 01:49 PM
YJ Front Speaker Replacement - 5.25"??? BrooklynBridger Audio, CB & Ham Radios, GPS, & Electrical 5 04-28-2008 03:09 PM
Speaker suggestions 2-10" or 1-12" ? Unscathed Audio, CB & Ham Radios, GPS, & Electrical 5 11-04-2007 11:19 AM
Radio speaker "buzz" thinkwoods Audio, CB & Ham Radios, GPS, & Electrical 2 08-03-2006 10:42 AM
