Quantcast 33 engineering sub box in a tj - Page 4 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > 33 engineering sub box in a tj
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 01-26-2009, 10:25 PM   #46
SirGCal
SirGCal's Avatar
yes people have shoe-horned in two 10's. going under the specs for volume spikes the frequency. Basically it becomes more SPL oriented, less SQ. Go too far too small and you mess with the suspension of the speakers and pressures they expect to see and could cause problems.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 01-26-2009, 11:26 PM   #47
NDSpeed
I need these instructions too. i am replacing my stereo now too. already have the speakers, the only other postion i have heard of is in the wheel wheel on the opposite side of the gas tank
NDSpeed is offline   Reply With Quote
Old 01-28-2009, 07:14 PM   #48
2003X
2003x
2003X's Avatar
I have two 12" subs in my TJ. It is REDICKKKKK LOUD .
2003X is offline   Reply With Quote
Old 02-02-2009, 08:34 PM   #49
jhh
Almost finished with the in seat sub build. Just wondering what most folks who have done this
used to connect the wires for the subs. I was thinking of some type of compact banana plug terminal
so that if the seat needed to come out, it would not be too difficult. Any thoughts? Best location on the box?
jhh is offline   Reply With Quote
Old 02-03-2009, 07:07 AM   #50
apollojeep
Junior Member
Seems like I have seen a picture of someone whol built this box with one 10" and mounted the amp on the other side of the box so it's all in one piece. That's what I was thinking about running... Any thoughts?
This would allow me to remove the rear seat and all components in one snatch just leaving some cables connected.
apollojeep is offline   Reply With Quote
Old 03-11-2009, 06:44 PM   #51
2k3r1
anyone have pics of this?
2000 TJ Sport, 4.0L, 5-spd, RE 3.5" with all 8 adj arms and adj trackbars with 35"s, D30 w/ Lockright, 8.8 rear axle, sye and CV driveshaft, M.O.R.E. 1" BL and MML, IPF headlights w/ H4 FATBOY bulbs, PSC power steering skid, rock-it man rockers, uniden pro 520xl WITH PA :)
Future mods: 4.88s and ARBs?, belly up, dif guards, Gastank Skid.
2k3r1 is offline   Reply With Quote
Old 03-11-2009, 10:14 PM   #52
samger2
Originally Posted by latsyrcmai View Post
Somebody mentioned putting an amp in the console.....FYI not a good idea unless you run some kind of fan to cool it off (which kind of kicks the stealth factor out). I stuck my amp in the console (years old sherwood 180 watt) and after a few months...burnt plastic smells started. Moved the amp..no more stench! VOLIA!?
I'm curious to see if mine continues to be ok...
I removed the insert from the console, cut out both ends of it so I can get to the speaker and RCA hookups easier and mounted the amp to the side closest to the driver seat with some nuts and bolts. Then I just slid the console over top and refastened the insert to it with new nuts and bolts as well. So far it hasn't heated up at all...maybe I didn't give it enough time to, but I played my stereo for about a half hour then opened the console and stuck my hand inside and the air wasn't warm at all and I smelled no burning.
samger2 is offline   Reply With Quote
Old 05-02-2009, 08:37 PM   #53
Fallen7s
Originally Posted by Mon Don View Post
What kind of subs do you have in there?
A little late, but if you're checking back at all... those are 2 10" rockford fosgate subs. I got them off crutchfield about 3 years ago for $99 for both of em.
Fallen7s is offline   Reply With Quote
Old 10-02-2009, 04:40 AM   #54
wpark013
Should I go with 1 12" or 2 10" subs?
wpark013 is offline   Reply With Quote
Old 10-02-2009, 10:01 AM   #55
spyder6
Just violated my Parole
spyder6's Avatar
that was me. going on a year and a half with it there and no problems - granted its only a 350 watt alpine.
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 09-08-2010, 09:40 PM   #56
tidbit
If anyone is still thinking of getting one of these boxes, I have one I never got to use. Held onto it thinking I would have another jeep by now (Had to sell my TJ to buy the wife a minivan). Call me if you live in the Tampa FL area (813-787-3179) I still have a few things I'm trying to unload like this sub box setup.
tidbit is offline   Reply With Quote
Old 11-03-2010, 12:37 AM   #57
AKeate
Bump for a solution!
I need a similar set up. I still want to have the option to take out the back seat w/out having to spend a chunk of time with wiring. (I really really hate messing with wiring.)
AKeate is offline   Reply With Quote
Old 11-03-2010, 09:19 AM   #58
Phreak480
what about using a wiring pigtail that extends a few inches from the box? i would find a suitable connector for the size wiring you are using. me personally i'd likely use anderson power poles in the 30 amp size because i have a ton of them around for various other things. be sure to use something that doesnt leave an exposed contact which could short out
Phreak480 is offline   Reply With Quote
Old 11-03-2010, 10:51 AM   #59
MK116V
Here is mine that I recently finished. Sirgal idea, but had to redesign it to use 3/4" mdf, and wanting to moutn the amp also in the seat. 8" Earthquake sub (150 rms) and MTX 421d amp (150 rms). Works great so far, but I want to find connectors for the wiring in case I want to remove the seat.
MK116V is offline   Reply With Quote
Old 11-03-2010, 03:01 PM   #60
AKeate
Is there a high enough pigtail? And pictures? I'm not too great at electrical...
Thanks in advance.
Glock Forum
