#31 | |
You get what you pay for
SirG has all of the plans/blueprints off of his website. You'll have to modify it a bit by adding a port, and double check the volume of the box vs. the sub itself and what it requires for a port volume, but It should be possible. Would look really good too. Just cut out a hole for the port out of the seat fabric.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville “Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain † Christian Jeep Club † Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38 |
#32 |
So a 'port' is just a slit in the box? Hmm, sounds easy.
#33 | |
Ohhh no... a port or vent for a box is an airway that is tuned (specific volume of air (size) and specific length) for the sub/box/vehicle.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
#34 |
I like your design very much! As soon as I have tools and $$$ I will be working on that!
#35 |
Currently working on semi ported Dual 10" Box in seats... Will keep updated
#36 | |
Semi-ported? Hu? If the box isn't sealed, it will make horrible resonate and velocity noises. If the box is ported but not properly tuned, it would be that x 100.
#37 |
Any other 33 engineering owners? Like Sirgcals design as well. What are the design differences?
I'm thinking about a single 10". Also, what amps will work and also fit in the OEM Sub console? Will the '03 and up seats have foam on top and be more uncomfortable?
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KM2s 2005 Rubicon, RE 4.5/3.5" SF, 285 KM2s sold 99 Sport, BB, BL, MML, 33s, sold |
#38 | |
Design difference between mine and 33eng is mine is more comfortable (made full width of the seating area instead of sitting on a corner designed only to fit within the frame). mine doesn't require a lift as the result of the install. Mine was designed for quality sound and comfort first, 33's, while a fine product, was designed for speed of manufacturing and simple construction. Mine is more complicated, but those are the benefits of that effort.
#39 |
Thanks. I've decided I'm going to build your design. Would you still recommend the 5.25 Polks and the Pioneer shallow sub? I've got a Sony CDX GT610UI with only one pre-out, so will just have a sub amp and power the speakers from the HU. Ditching the HU is not out of the question, but it is pretty new and I like it otherwise.
Do you prefer the sinlgle 10 or 2 8" subs? Which amp for either? I'd really like to have an amp like the MRP M450 in my sub console. I have the trunk, but would like to keep the space open. You use the 33 engineering 5 1/4 dash plates, correct? Any recommendation of where to order?
#40 |
I wasn't aware there is a difference between 97-02s & 03s+ rear seats.
2005 4.0 LJ Auto, BFG AT 32x11.5x15, Spidertrax, Kenwood Excelon X591, Alpine EX-10 iPod/BT, Sony XM-4S amp, Polks, 5.25" Dash Speakers, MTX sub, Hella H4 Conversion/Fatboy II, Euro Clear Lenses, KC Rear Fog, Light Guards, Bug Shield, Olympic Grille Guard, Delta 150 Amber Fogs, KC Long-Range Daylighters on A-Pillars, Rubicon Rockers, Power Step, Skid Row Steering Box Skid, Warrior Rear Diamond Plate Armor, Skyjacker 2BB/Steering Stabilizer/Hydros, Rear ACOS, Volant CAI/Snorkel, Bestop Tire Carrier, PW/PDL, 4" Xenons, ARB D30 & Rockcrusher D44 Diff Cover, CA Skids, Radiator Guard, Trailjammer, LED Tails, 4.88s. |
#41 |
Somebody mentioned putting an amp in the console.....FYI not a good idea unless you run some kind of fan to cool it off (which kind of kicks the stealth factor out). I stuck my amp in the console (years old sherwood 180 watt) and after a few months...burnt plastic smells started. Moved the amp..no more stench! VOLIA!?
#42 | |||
#43 |
This is a relatively old article but is very interesting!
1998 TJ: 33" MTRs, 30/8.8(lsd), XD9000i 2006 Sierra (tow rig) |
#44 |
Article?
Why would you bring it back?
White 2WD 1995 ZJ 4.0 Jesus the Christ is my Lord and Savior. I know Him, do you? Future Mods: get it working correctly |
#45 |
After reading about this and studying the plans and pics, I am going to build one.
Has anyone ever tried this with two 10" subs? Seems like some of the pics are of two 10". Does anyone know what the downside is of having less than recommended internal volume in a sealed box of this type? Thanks |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
