2ways or 3ways - JeepForum.com
post #1 of 4 Old 10-15-2001, 06:52 PM Thread Starter
TJSahara
Post 2ways or 3ways
what is better sounding the soundbar a 2-way or 3-way speaker. It is an 01 TJ w/ 5-1/4's. I was thinking of running a component set, but if I don't have to then I won't waste the time. Thanks for the help
01 XJ Sport - 3" OME, trXus MT
TJSahara is offline
post #2 of 4 Old 10-15-2001, 09:51 PM
evilpsych
evilpsych's Avatar
Post
from what i've read.. 3ways would be the way to go.. 3 diff speakers handling diff freq range.. probably better sounding than 2 ways.. depends on the frequency response of the speakers themselves.. plus i might be a little worried about distortion in the mid to hi range from the lowrange woofer in that 3way setup
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 4 Old 10-15-2001, 10:06 PM
Jefff
Post
I put a set of Sony 5 & 1/4 3 way speakers in the soundbar of my TJ, and took them out 5 minutes later. The stock speakers sounded better!
I'm looking to put in a set of 2 way 6 & 1/2 speakers instead. All you need to do is put a spacer of sorts in & they'll fit.
Jefff is offline
post #4 of 4 Old 10-15-2001, 10:07 PM
Willis91YJ
Post
Hey bud,
It depends on what speakers specifically you are talking about. Alpine makes a three way for about 85 bucks and they make a "two way" for 250. The difference is not in the "ways" per say but in the two way as in all good woofer tweeter setups is that the speaker that is mounted inside of the 5'1/4 is a silk dome tweeter with much better frequency response than any "three way" on the market. If you e-mail me with the speakers you are trying to decide between I may be of more help!
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
Cobra 2ways CherokeeTank Audio, CB & Ham Radios, GPS, & Electrical 2 05-17-2006 07:24 AM
