2007 jeep grand cherokee limited starter issue - JeepForum.com
post #1 of 5 Old 03-13-2014, 12:30 AM Thread Starter
justlivin14
I got this jeep just after Christmas. It runs great. A few weeks ago it would click when I try to start it. I ole oils try it a couple more times and it would start up. Last week it would only click. I ordered a starter and went to see about changing it and jacked it up, disconnected the battery and realized this is going to be a pain. I reconnected the battery and tried to start it and it started right up. I'm thing a loose connection but I can barely get to the starter much less check the connections. Any ideas?
justlivin14 is offline
post #2 of 5 Old 03-13-2014, 12:02 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Does it still stat right up? Have you tried it again?
JeepCares is online now
post #3 of 5 Old 03-13-2014, 06:08 PM Thread Starter
justlivin14
I tried this morning and got nothing but a click. Tonight I'm going to try and check the connections. Very difficult to get to.
post #4 of 5 Old 03-14-2014, 08:04 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
From the Service Manual section on diagnosing "STARTER FAILS TO OPERATE"
1. Battery discharged or inoperative
1. Charge and test battery. Replace battery, if required.
2. Starter motor or solenoid inoperative
2. Test the starter motor and solenoid. Replace starter motor, if required.
3. Starter relay inoperative
3. Test and replace the starter relay, if required.
4. Clutch pedal position switch inoperative (if equipped with manual transmission)
4. See Clutch Pedal Position Switch. Test and adjust or replace switch, if required.
5. Park/Neutral position switch inoperative (if equipped with automatic transmission)
5. See Park/Neutral Position Switch. Test and adjust or replace switch, if required.
6. Ignition switch inoperative
6. Test the Ignition Switch and Key Lock Cylinder. Replace ignition switch if required.
7. Starting circuit wiring inoperative
7. Test and repair starter feed and/or control circuits, if required.
post #5 of 5 Old 03-14-2014, 12:36 PM Thread Starter
justlivin14
Thank you for the information. I looked at it last night and I moved the positive connection to the battery back and forth and it started right up. I am pretty sure it is a loose connection but I can't get to the starter to check the connections. I am going to attempt to check them tonight when I get off work.
