2005 Wrangler Radio Removal - JeepForum.com
post #1 of 8 Old 06-20-2005, 09:45 AM Thread Starter
2005300C
How do you remove the cover around the radio/heater controls? I want to remove and install a different radio. Thanks
2005300C is offline
post #2 of 8 Old 06-20-2005, 09:53 AM
Rocky529
Rocky529's Avatar
If I'm not mistaken, it just "pops" off.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 8 Old 06-20-2005, 09:54 AM
Wheels4186
Wheels4186's Avatar
Ok first you want to pull the defroster plate off on the top of your dash (it just snaps upwards) once that is remove there is 2 screws that hold the console on.....remove those screws and then just pull it forward/downward and it will slip right off with a little force.....Once that is done, remove your glove compartment door and reach back behind the head unit to a bolt that connects the radio to the ground. then theres 4 bolts on the radio front and remove the antena. Sounds like alot of work but it should take you maybe 10 minutes....You will also have to remove a plug off the back of the head unit.
Dave
Dave
04 Patriot Blue TJ- DAILY DRIVER/WEEKEND WARRIOR D-30/60 7.5" of lift, 38's, bumpers, cage, OBA, winch, armor, tube fenders, 2000W Stereo, etc.
Wheels4186 is offline
post #4 of 8 Old 06-20-2005, 09:54 AM
TXST8tj
TXST8tj's Avatar
take a flathead screw driver and pop the long narrow plastic piece off the dash just at the base of the windshield. that will expose two philips screws at the top of where the coin tray is. take those out. pull the cig. tray out and that will expose one more screw, take that out. i find it easiest to pull from the bottom from that point, pulling the entire plastic surround off the dash.
Patrick
TXST8tj is offline
post #5 of 8 Old 06-20-2005, 10:07 AM
SMACC
SMACC's Avatar
on my '05, it's just as stated above however no ashtray. Only the two screws you'll find after lifting of the defroster strip.
Purchased New May 14,2005
2005 Wrangler Rocky Mountain Edition,
Patriot Blue
4.0 Liter, 6-Speed, Dana 44, 3.73
Rubicon Express 2" Budget Boost
TeraFlex Swaybar Quick Disconnects
Kilby Onboard Air Compressor
XM/AM/FM/CD
Hidden Hitch 2" Receiver
Olympic Light Bar
1978 M416 1/4 Ton Trailer
Patriot Blue Jeep Club Member #4
SMACC is offline
post #6 of 8 Old 06-20-2005, 11:22 AM
phildaug
phildaug's Avatar
The part you need to remove to get to the radio is called the Bezel.
To remove this pop off the defrost cover strip along the top of the dash, it just pops out with a flat blade tool. You will see the two philips head screws on the top. Remove them, not sure of your year, but if you have a ashtry take that out and remove the screw in the back there also. The bezel will just be held by panel clips then. Pull gently along the top and bottom and off it will come.
Your factory stereo should just have two screws in the face plate. You will also have what is called a anti-theft device attached to the back of the head unit. If your stereo is the older style (square corners) mopar radio it will be a steel strap that you can pull out. If it the head unit like mine with the rounded corners it will have nut you need to get off the back of the head unit.
to get to the nut take off you glove box door and reach up behind the radio, you will find it. It is a 10mm nut, that comes off real easy. depending on the size of you new head unit you maight need ot remove the factory security hanger also. It is held in place by two bolts along the top of the dash. Not a hard thing to get out through the glove box.
Just be careful fishing it out of the dash, it want to grab wires as it comes out
The funny thing about that security device is that is also acts as the gound for the head unit, so you might not see a ground wire on your harness.
Good luck.
2004 Wranger Unlimited. Airaid Intake, TRD Throttle Body, Borla-Cat back, 3" BDS-LIFT, sitting on 33-1250 Yokohama's & MT Classic w/ RED Lock rings Pioneer Head unit with a eclipse 4-channel pushing Memphis Car Audio speakers Kenwood Sub.
phildaug is offline
post #7 of 8 Old 06-20-2005, 01:54 PM
Dr. Internet
All of above is correct. If you put it all back together and get no radio, check behind the glove box. There is a connector splice for the radio antenna inside the foam covering that comes unplugged every time I take mine apart. It just plugs back together.
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #8 of 8 Old 06-20-2005, 02:24 PM
JordyX
A side note.... I recently Installed my new stereo and I removed the security bracket. The radio was not grounded properly as I was getting lot of electrical static and getting shocked a lot more then usual. So I fabricated a ground wire with a ring on the end that fit over bolt that is up by teh windshield that the bracket was on, I then just put the nut back on to hold the wire on, the other end of the wire was attached to the back of the new head unit, that solved all my problems.
Hope this helps if you have teh same grounding problem I did
-Jordy
'05 Green Wrangler X
JordyX is offline
2003 Wrangler Radio harness / Sub/ Amp removal question. 0okamiDigital Audio, CB & Ham Radios, GPS, & Electrical 2 03-09-2009 12:04 AM
2005 LJ Radio question, ipod? tadst1300 Audio, CB & Ham Radios, GPS, & Electrical 12 02-19-2009 07:18 AM
2005 Jeep GC limited REC Radio/Nav Cerealkiller Audio, CB & Ham Radios, GPS, & Electrical 0 01-31-2009 08:28 PM
need 2005 TJ radio pinout majkowskid Audio, CB & Ham Radios, GPS, & Electrical 4 08-06-2008 05:28 PM
REC Navigation radio in 2005 Wrangler? RouDaddy Audio, CB & Ham Radios, GPS, & Electrical 2 09-15-2005 10:41 AM
