2004 Jeep Wrangler Wiring Diagram Needed - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > 2004 Jeep Wrangler Wiring Diagram Needed
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 08-31-2009, 11:32 AM   #1
k00s
Hi All
I need a wiring diagram for a 2004 Wrangler, my turn signals do not want to work and I have checked the fusses and the switch and the relay all are working. I now want to check the wiring of the vehicle as I dont know what else to check Please any info will help if you dont have a wiring diagram.
k00s is offline   Reply With Quote
Unread 08-31-2009, 12:11 PM   #2
rubibluejay
First, welcome to JF. This link should help you out.
http://www.jeepforum.com/forum/f9/so...rds-do-342213/
Here's a pinout for the multifunction switch.
http://www.jeepforum.com/forum/6644050-post3.html
Jay
rubibluejay is offline   Reply With Quote
Unread 08-31-2009, 12:34 PM   #3
k00s
Thanks for the welcome, I think this will help me alot... Thank you!
Unread 08-31-2009, 01:34 PM   #4
mylt1
check the grounds first then the actual bulb plugs. any corrosion in the sockets could be causing issues as well as corrosion on the grounds.
mylt1 is online now   Reply With Quote
Unread 09-17-2009, 02:07 PM   #5
ericsRHD
undre the hood, in the fuse box is a fuse marked MFSW or something like that. The fuse is prolly blown. There is a fuse for both the turn signal and one for the switch
ericsRHD is offline   Reply With Quote
Unread 09-18-2009, 12:04 AM   #6
k00s
Thanks Guys will check it out...
