2001 TJ Auxiliary Power Wire Location [Photo] - JeepForum.com
post #1 of 9 Old 08-22-2010, 07:31 PM Thread Starter
Sleeperman
It took me a while to find these. Their existence and location have been described, but a picture is worth 1K words:
Remove the glovebox and find the harness labeled above; the wires are clearly labeled, and secured/obscured with electrical tape. Hope this helps!
Sleeperman is offline
post #2 of 9 Old 08-22-2010, 11:19 PM
Photog2000
I was starting to think my owners manual was lying to me until I found mine about as month ago.
Photog2000 is offline
post #3 of 9 Old 07-13-2011, 03:24 PM
esad_b
I cannot find these for the life of me in my 97 tj...
Any idea what I could run my "arm" switch to for my winch.. I really do not want to run another wire all the way to the battery.. I was going to do the cig lighter but thats constantly ON.
esad_b is offline
post #4 of 9 Old 07-13-2011, 09:14 PM
Photog2000
Did you look right above the fuse box? I think mine were tucked into the heat duct.
post #5 of 9 Old 07-14-2011, 05:07 AM Thread Starter
Sleeperman
Remove the glovebox and locate the wiring harness shown in the picture. The auxilliary power wires should be secured to the harness with black electrician's tape; you might have to dig for them.
post #6 of 9 Old 07-14-2011, 05:32 AM
esad_b
I did that. I peeled off the tape and it appeared to me all wires were in there tight and I could not pull any out. I tried pulling on the blue wire but it as in there good.
Would the switched 3amp wire even be adequate enough for me to run to my "arm" switch for the winch?
esad_b is offline
post #7 of 9 Old 07-14-2011, 05:55 AM Thread Starter
Sleeperman
The power requirements for the winch should be specified in the installation guide. Without auxilliary power wires, direct from the battery is probably gonna be your best bet; it's easily done, and the necessary wiring may be included with the winch.
post #8 of 9 Old 10-01-2011, 11:32 AM
Jebussaves0
OK... I took a shot at this and couldn't find them either on my '02. I located the wiring harness and, just as the previous poster noted, the wires located inside are tightly bundled together and un-labeled.
Just to clarify, are the auxiliary power wires INSIDE the harness or merely secured to it?
2002 Jeep Wrangler Sahara | 4.0L 5spd D44/D30 3.73s | Hurst Shifter |
| Hummer-Style CAI | 1" Rusty's BL/MML | AA TC Shifter Bracket | 2" BB | JKS Quicker Discos | 33x10.50R15 BFG KM2s | Alpine CDA-9886 HU | OTRATTW Switch Panel | G.P.F. Rear Bumper | Metalcloak Overline Fenders
M416 Trailer | In Progress
Jebussaves0 is offline
post #9 of 9 Old 10-02-2011, 06:21 AM Thread Starter
Sleeperman
On my '01 Sport, the Auxilliary Power wires were secured to the main harness with black tape. The picture shows them freed up, and the labels exposed.
Using amp power wire as 12V source for auxiliary backup lights Maxxram Audio, CB & Ham Radios, GPS, & Electrical 1 03-13-2009 09:02 AM
New Stereo.. What wire is the Power ANT wire?? HELP smokin_gun Street Jeep Forum 5 06-06-2008 03:40 PM
Hot wire location for CB TJ3355 Audio, CB & Ham Radios, GPS, & Electrical 4 12-26-2006 03:30 PM
Need help locating the Auxiliary Power wires behind Glove Box Niles Audio, CB & Ham Radios, GPS, & Electrical 6 12-10-2005 03:34 PM
Auxiliary Power ncb76 Audio, CB & Ham Radios, GPS, & Electrical 14 10-20-2005 07:43 AM
