1995 Wrangler 3rd Brake wiring - JeepForum.com
post #1 of 1 Old 05-21-2010, 06:49 PM Thread Starter
JoeR203
Question about the 3rd brake wiring.......in the wheel well there's a wire with a rubber banana plug type connector just dangling. I don't know if I pulled it loose when I unplugged the harness, or if it was never connected. It seems like it would go to the rubber grommet that the 3rd brake's ground wire would contact when the tailgate is closed, but there's no way that plug will attach to that grommet. Is it supposed to connect to it? Or just hang loose?
Also, I'm in the process of wiring up LED tail, reverse and side marker lights. Can I splice all ground wires together and attach to one central grounding point? I know I'd lose all lights if the ground came apart, but what's the likelihood of that happening? Just a street Jeep here. Or is it best to give each light it's own separate ground? And if the grounds are wired separate, can I attach them to one point?
Whoever said "Money can't buy happiness" didn't know where to shop.
JoeR203 is offline
1995 Jeep Wrangler 4Wheel drive question Cordova_1 Engines & Drivetrain 1 02-06-2012 01:31 PM
1995 Wrangler clutch replacement question? thekauz Engines & Drivetrain 10 12-14-2009 01:50 PM
what size speakers fit in dash of 1995 wrangler? yjwrangler Audio, CB & Ham Radios, GPS, & Electrical 3 08-03-2009 02:10 PM
Added A/C system to 2.5L 1995 Wrangler, Do I need electric fan? Millertime Engines & Drivetrain 2 06-07-2002 12:23 PM
2 inch Body lift on 1995 Wrangler 2.5L Millertime Tires & Wheels 3 04-26-2002 04:37 PM
