1980 CJ-7 Painless Engine Harness Confusion - JeepForum.com
post #1 of 1 Old 12-19-2012, 02:09 AM Thread Starter
Marca
1980 CJ7
Recently got my first Jeep, and hasn't taken long to put together a wish list of stuff I'd like to do! Since I'd like to add a lot of electrical improvements, I decided to start by adding a new alternator (the Powermaster 67295-303), which I installed without trouble.
However, my next step was to install a new wiring harness. I bought the Painless 10110 complete Jeep harness. Got the dash harness in no problem, mounted the engine bulkhead connector, and then totally panicked! The Painless manual (here's a link) gets WAY more confusing once you get into the engine harness. I've got lots of questions, but here are a few for starters (by the way, it's a 1980 CJ-7 with the inline 6):
1. I'm assuming the ignition control module is the little silver box on the fender below the engine bulkhead connector. It's got multiple wires running across the engine bay to the distributor. Do I need to cut any of these and splice the Painless harness in, or should I just keep the old wires? The old harness seemed to connect to the control module so I'm sure I'll have to splice it in somehow...
2. The manual has several different wiring diagrams, and I can't quite figure out which one I'm using. It looks a lot like the Duraspark ignition system but I can't be sure and I wonder if anyone knows what would make sense for an 80 CJ-7 with inline 6?
3. Section B of step 6 in the manual tells how to wire the ignition module group of wires. However, it completely leaves out Duraspark! There are only instructions for "Motorcraft," "Prestolite," and HEI and point style ignition systems." The manual does refer people with Motorcraft ignition module to the illustration for Duraspark, but then it goes on to tell you to wire the light blue wire #719 to the two-way connector of the ignition module. How am I supposed to do that if I've already wired #719 to the starter solenoid? Any ideas, or am I missing something?
As you might have gathered, i'm a novice with all things automotive including Jeeps, so any help is greatly appreciated!
Marca is offline
harness , ignition , motorcraft , painless , wiring
