Quantcast 05 GC fog lamps wont come on - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > 05 GC fog lamps wont come on
Old 08-09-2008, 07:43 AM   #1
Cayton427
2005 FSJ Cherokee
Hello all, new here...so forgive me if I am in the wrong place or breaking any other known guidelines. My question is simple...My 2005 GC fog lamps wouldnt come on during state inspection, the bulbs had a bit of fogginess to them...so I assumed they had gone bad. Last night, however, after replacing both bulbs...I have nothing. Checked the fuses, all other running lights...everything looks fine. My question is this, is there a problem or issue that is prevelant that I dont know about...or am I most likely dealing with a wiring problem here. Any advice would be appreciated. Thanks!
Cayton427 is offline   Reply With Quote
Old 08-09-2008, 09:07 AM   #2
SirGCal
SirGCal's Avatar
Right place...
Problem could be many things. Start with the obvious fuses and such. Then move to switches and wires.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 08-11-2008, 08:41 AM   #3
mylt1
just because the fuse looks good doesnt mean it is. replace it, there cheap. then see what happens. if that doesnt work check the ground to the lights.
mylt1 is offline   Reply With Quote
Glock Forum
