ZJ rear tire carrier build - JeepForum.com
post #1 of 18 Old 02-21-2012, 09:44 PM Thread Starter
PurpleZJ
Awhile back I decided to build a rear tire carrier for my ZJ that would incorporate the stock rear bumper. I used my hobart 140 handler welder using 0.030 flux core wire. I bought 10' of 1/8" wall 2x3 tubing and 15' of 1/8" wall 2x2 tubing. I have about 3-4 feet of the 2x2 tubing left over, and the A to Z tire carrier fabrication kit
I started by building this section.
added on this section of tube, this is the main base that the swingarm spindle and latch will be mounted to. you can also see the holes i drilled for the nutserts that will be used for mounting
here is the spindle ready to be welded in place. i had to notch/bend the end of the tube otherwise it hit the rear bumper when in place
spindle welded in
this is the tube that goes over the spindle, being heated up to put the bearing races in place.
when welding the swingarm together make sure it does not warp at the welds, mine did and i still need to fix it. with the 2x2 for the vertical support i notched out the sides so it would slide over the 2x3
cut out and welding the first angled support in place. sidenote: pay attention to how high you make the vertical support, I made mine too high so now the back glass does not open with the carrier shut and i need to fix it.
next angled support tacked on
i measured and cut this piece to make the tire mount tube and to cap the vertical support
tire mount plate tacked on
test fit
I felt it needed a support between the vertical tube and the tire mount tube so i cut one out after measuring to make sure it would not interfere with the tire when mounted
here it is all finished
rear mirror view, its not so bad when my license plate wasnt mounted inside the spare rim because i could see through the holes
and here is a final pic mounted with no spare
word to the wise, when mounting the wheel studs to the wheel plate- get some washers and a lugnut, get it snug against the hole then use a hammer to force the stud into the hole. be careful to make sure you dont get them all cockeyed. there ya go guys hope this helps
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #2 of 18 Old 02-22-2012, 11:15 PM
Midnightluckey
Sweet! I was hoping you would make a write up on this.
It reminds me that I need to get on with mine.. If i can just bring myself to take a wire wheel to the powdercoat.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #3 of 18 Old 05-18-2012, 04:25 PM
ELMCZJ95
would you be willing to make and sell me one??
Jeep Grand Wrangler Build Thread: http://www.jeepforum.com/forum/f13/jeep-grand-wrangler-build-1398775/#post13935376
ELMCZJ95 is offline
post #4 of 18 Old 05-18-2012, 04:28 PM Thread Starter
PurpleZJ
where are you located? and maybe, I have a full plate this summer with summer classes, my jeep, and building a front and rear bumper for bigbluezj94
December 2010 GCOTM
04/28/58-2/13/11
PurpleZJ is offline
post #5 of 18 Old 05-18-2012, 04:40 PM
biggoofy
You going to Vegas lol
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #6 of 18 Old 05-18-2012, 04:44 PM Thread Starter
PurpleZJ
Sadly no, I'm building them and then shipping them to her. I'm basically doing it for free, she covers materials and shipping.
December 2010 GCOTM
04/28/58-2/13/11
PurpleZJ is offline
post #7 of 18 Old 05-18-2012, 04:58 PM
ELMCZJ95
I'm in Tampa, FL
ELMCZJ95 is offline
post #8 of 18 Old 05-18-2012, 09:44 PM
biggoofy
That's where I'm from lol
Zack
13 JKU Stock
biggoofy is offline
post #9 of 18 Old 05-18-2012, 09:49 PM
ELMCZJ95
Yeah, I saw your USF Knights sticker on the back of your jeep
ELMCZJ95 is offline
post #10 of 18 Old 05-18-2012, 09:50 PM
biggoofy
Usf bulls the knights are Ucf
Zack
13 JKU Stock
biggoofy is offline
post #11 of 18 Old 05-18-2012, 09:51 PM
ELMCZJ95
Yeah that one, hahaha
ELMCZJ95 is offline
post #12 of 18 Old 05-19-2012, 12:12 AM
Jones
Consider the following...
Jones's Avatar
I love the way that turned out. Your design should have been a factory option.
Jones is offline
post #13 of 18 Old 05-19-2012, 02:08 AM Thread Starter
PurpleZJ
Thanks man, I've since re worked it by moving it passenger about 6" and lowering it 3" to accommodate a larger tire than a 33 since I'll be running 37s soon
December 2010 GCOTM
04/28/58-2/13/11
PurpleZJ is offline
post #14 of 18 Old 05-19-2012, 05:10 AM
billyzj
1994 ZJ
looks good,been thinkin about doing the same thing,just need to get the steel
billyzj is offline
post #15 of 18 Old 05-19-2012, 10:05 AM Thread Starter
PurpleZJ
UPDATE
re worked the tire carrier to accommodate larger tire and to fix a warp issue
Cut a slit to level out the swing arm
Welded and braced
Moved over 6 inches and lowered 3
Welded and painted. Still have to weld the latch
December 2010 GCOTM
04/28/58-2/13/11
PurpleZJ is offline
my wj rear bumper build with tire carrier wonderbrd937 Grand Cherokee General Discussion 82 06-05-2011 11:27 AM
arb rear bumper w/ tire carrier vs currie rockcrawler2 w/tire carrier and rockribs lstcj7 Wrangler General Discussion 0 07-03-2010 07:57 AM
Decide to build a tire carrier NEVADAGARY ZJ Grand Cherokee Forum 70 06-14-2009 11:39 PM
will cj rear tire carrier fit on yj with 32" tire rficken42 Wrangler General Discussion 1 01-05-2009 03:20 AM
