ZJ driveshaft swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > ZJ driveshaft swap
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 12-19-2011, 01:16 AM   #1
MoparBoy01
ZJ driveshaft swap
I'm in the process of parting out my 98 ZJ 4.0L. It has the 242 tcase and ujoint sytle driveshaft. My new ZJ project is a 98 5.9L ZJ. The 9'er used to have a front driveshaft (u-joint style) on it but was stolen from the dealership I got it from . I plan on installing the 242 in the spring time but I want to use the front driveshaft for the winter. Would it be possible for me to take the DS off of the 4.0L and put it on the 5.9L. Any help or suggestions would help. Thanks.
1998 ZJ 4.0L-Trail Rig
1998 ZJ Black 5.9L-Prerunner/Daily Driver
1999 XJ 4.0L-Daily Driver/sometimes a weekend warrior
Down and Dirty Offroad Club Member
ddoffroad.com
MoparBoy01 is offline   Reply With Quote
Unread 12-19-2011, 03:53 AM   #2
Technohead
Old school
Technohead's Avatar
Chances are you will need to change the yoke on the pinion. Otherwise you can get your anwer with one of these:
Technohead is offline   Reply With Quote
Unread 12-19-2011, 08:30 AM   #3
ZJ_flexxxer
ZJ_flexxxer's Avatar
1994 ZJ
it should be telescoping right? best bet is to just measure it. my thoughts are that it should work but that's just my guess lol
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's BUILD THREAD
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress BUILD THREAD
87 XJ Wagoneer--R.I.P. =(
SUBSCRIBE TO MY YOUTUBE CHANNEL!
ZJ_flexxxer is offline   Reply With Quote
